Roof sound deadening
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, May 22, 2023.
  1. May 22, 2023 at 5:54 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Hey guys - if you have a sunroof, is there much to sound deaden on the underside of the roof? I ask bc the sunroof has a steel plate behind it and I’m not sure there’s space to add dynamat between the headliner and that plate .. so before I remove it I’m asking you guys if there’s that much to deaden
  2. May 22, 2023 at 5:59 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Have you applied sound deadening material on the floor, doors, and back of cab?
  3. May 22, 2023 at 6:09 PM
    TacoRancher
    Houston
    Question is really just about the roof. The back story is I’m going to have to get the headliner dropped for another reason and so should I be there to add in some dynamat. I will get other parts deadened later.
  4. May 22, 2023 at 6:20 PM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    Might as well while its opened up. You will always wonder otherwise.
    TacoRancher[OP] likes this.
  5. May 22, 2023 at 6:23 PM
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    eurowner likes this.
  6. May 22, 2023 at 6:40 PM
    TacoRancher
    Houston
  7. May 22, 2023 at 6:59 PM
    TSki
    Tyler
    Salmon, Idaho
    Not sure on the wires, but there was a decent difference. The sunroof quickly becomes the noise source. I feel like covering that would help as well.
  8. May 22, 2023 at 7:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
    musicisevil likes this.
  9. May 23, 2023 at 8:11 AM
    TacoRancher
    Houston
    How much material did you need? And why did you need tape? I’m going to get dynamat xtreme
  10. May 23, 2023 at 8:18 AM
    TSki
    Tyler
    Salmon, Idaho
    I honestly can't remember how much I used for that area it's been so long. The tape was just because I was doing overkill. Likely unnecessary, but every little gain counts for something!
  11. May 31, 2023 at 12:50 PM
    TacoRancher
    Houston
    Anyone know the gap size between the sheet metal and the headliner? I’m asking because I plan to install dynamat extreme and then dynaliner on top and the dynaliner comes in 1/8”, 1/4” and 1/2” and I don’t want to go too thick and cause issues reattaching the headliner. If it’s unknown I’ll just go with 1/8”.
