Roofrack Basket (design pic)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tooblutacoma06, Aug 14, 2009.
  1. Aug 14, 2009 at 12:59 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    Whatup er'body! For the past couple of weeks I've been designing a gear basket to mount to my roof. A big thanks goes out to TW member Kasey for the inspiration and help. I think I've got everything pretty much nailed down on it and I'll be starting on the fabrication next week sometime. I do however, have a few issues I need to clear up before I start the build.
    My design is one that will easily mount to the OEM roofrack's crossbars. Thus I could take the basket off quickly if need be. One thing about this is that the OEM racks aren't cheap, and have a silly low load capacity. My other thought was to just make some legs and feet welded to the basket to directly bolt into the channel and nuts that are in the roof already. That way, I would not have to worry about the load on the flimsy crossbars. I'm working on drawing up this last minute thought now.
    Until I can get the measurements of the holes and channel in the roof, I'm still going to design for mounting on the OEM rack. So here's where I could use a little help from you guys that already have the rack.
    -I need to know the horizontal distance between the top of the windsheild and the center of the forward crossbar.
    -Also, I need the horizontal distance between the center of the two crossbars
    -And lastly, I need the horizontal distance between the center of the rearward crossbar and the back of the cab (double cab).
    These are the last dimensions I need to finish up the design process.
    Here's a few views of the basket in it's current design stage:
    Let me know what you guys think!
  2. Aug 14, 2009 at 1:02 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
  3. Aug 14, 2009 at 1:03 PM
    phynyx38
    phynyx38 Believe
    San Antonio, TX
    08 Tacoma PreRunner
    Pretty cool!
  4. Aug 14, 2009 at 1:32 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice design. thats the way i would do it.
  5. Aug 14, 2009 at 1:43 PM
    TexasmadeYOTA
    TexasmadeYOTA Well-Known Member
    Florida
    95 v6 yota
    gainesville huh? thats 15 mins down the road... nice to see some more locals most are from jville or down south.... oh and nice rack:D
  6. Aug 14, 2009 at 1:43 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Nice...
    If made from steel, it may be getting on the heavy side... You could probably loose a few supports and gussetts... trim some fat to make it lighter...
    If made from aluminum, it would probably be light enough as is...
    just my $.02
  7. Aug 14, 2009 at 1:44 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I like it, looks like a cool design.
  8. Aug 14, 2009 at 1:54 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks for the compliments guys!
    The supports are such becuase I plan on making the basket out of 3/4" EMT Conduit. I have spoken to several people and they have assured me that the conduit will be strong enough with plenty of supports. Another reason to use the conduit is because the cost is in par with my budget. The bars across the bottom of the basket will be mild steel. I might have to change some design aspects once I get to fabbing it up and getting an idea of the overall weight. Because you are right, I don't want it to be too heavy.
  9. Aug 14, 2009 at 1:58 PM
    TL697
    Jacksonville, FL
    Cool... I was just thinking of all mild steel construction would get heavy...
    The thin-wall conduit should be pretty light...
    Maybe get an idea of what you would actually want to put up there, and then work from that...
    And, may be a few long-ways pieces across the bottom to create more of a "floor" in the basket...
  10. Aug 14, 2009 at 2:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  11. Aug 14, 2009 at 2:09 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks for lookin out on the weight though! And that's a good idea about covering more space on the bottom. I thought about trying to find some heavy duty mesh and securing that to the crossbraces so that little items wouldn't fall through. But if I can't find that somewhere I will definitely consider laying some more bars down.
  12. Aug 14, 2009 at 2:11 PM
    tooblutacoma06
    Kellon
    Houston
  13. Aug 15, 2009 at 4:02 PM
    tooblutacoma06
    Kellon
    Houston
    Bump...I'd greatly appreciate some help on these measurements guys!
  14. Sep 15, 2009 at 6:40 AM
    kk100
    kk100 Member
    Rapid City
    2009 Tacoma 4door. 3" toytec lift
    33" BFG's, 3" toytec lift - coils and add a leaf. Murdered out wheels, 2 10 Kicker CVRs behind seat, Clarion Doubled in Deck and a Kicker 1200.1 amp. ROCK THE HOUSE!
    looks like he copied my bros rack!
  15. Sep 15, 2009 at 6:41 AM
    kk100
    kk100 Member
    Rapid City
    sick though
