Room for a taller, wider driver?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by likeaHoss, Feb 4, 2020.
  1. Feb 4, 2020 at 7:29 AM
    likeaHoss
    likeaHoss [OP] New Member
    Well firstly I wouldn't be here if I didn't like Toyotas, but I need some help figuring out which model years might fit me best. At 6' 3" and 260lb-ish I like my Ford x-cab and slide the seat all the way back. Years ago I owned an '85 2wd reg cab Toyota and after about 4hrs of driving my right leg/knee was getting pretty sore so reg cab obviously not an option. Back in 2000 I sat in a brand new Tacoma and I felt like I was looking out the tinted portion of the windshield at the very top. I would prefer to find a factory fit that was pretty good rather than relying on a successful mod to make it satisfactory.
    The secondary but very important criteria is off-road features and relative ease of road-side repairs. I have an opportunity to build a small place to live that's on property 7 miles back on old logging roads that were cut in the 1940s. My x-cab long bed makes it but I have to drive about 8-9mph due to stiff suspension and higher tire pressures for load carrying. So the longer term goal for a Toyota is to dump some coin and upgrade the suspension to make the trips in and out a bit shorter and less jarring(Almost impossible to drive the road without having to stop and pee.) Bumpiest road I ever seen.
    So briefly, which Tacomas might offer a taller and wider person a bit more comfort, if there are model years with more electronic complexity I would prefer to avoid those, and the suspension will take a beating. Any tips/help is appreciated.
    Grindstone likes this.
  2. Feb 4, 2020 at 7:37 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I have a 2016 taco double cab without a sunroof and a 2016 f350 double cab. I am 6'3"/195lbs and 34" inseam/34" waist. The Tacoma is very near my lower limit for personal space and comfort on a long drive. I don't know if I'd recommend any Tacoma for someone 65lbs heavier than me. My issue is mostly leg room and getting the pedal to steering wheel relationship correct, which I think the Taco just can't do well. The 350 rides like a city bus but has so much more space. Different tools for different jobs obviously, but if any taco would fit you it would be a power seat model, which was 2019 and later I believe, without a sunroof. I sat in a sunroof truck and could not hold my head up.
    AKGSD likes this.
  3. Feb 4, 2020 at 7:38 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard. A full size man needs a full size truck.
    suaveflooder, Mr-Paul, AKGSD and 2 others like this.
  4. Feb 4, 2020 at 7:42 AM
    tgarza74
    tgarza74 Well-Known Member
    Mario
    2016 SSM TRD OR
    OvTuned
  5. Feb 4, 2020 at 7:43 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    As someone who is 6'4" and tipping the scales at 300 lbs I would say you might want to look full-size. I have a 34 inch inseam and I am at the very limits of my headroom tolerance. If my posture is like my mom would like it, I'm rubbing the headliner (sunroof) a tad. I added some blocks that are sold on here to lift the front of the seat. It helped, but it's not perfect.
    I also had to get an automatic because my knee just wouldn't do the clutch without poking myself in the eye.
    Look at all of your possibilities and test drive longer than the salesman wants to. Even with the above I still went with the Tacoma due to other reasons.
  6. Feb 4, 2020 at 7:51 AM
    Truks4elk
    Truks4elk Well-Known Member
    3rd gen 4x4 OR crew LB
    I’m on my third Toyota small pickup and at 5’8” I’ve still bashed my head a bunch of times getting in and out of them. It’s a ride for small to medium sized men or ones who REALLY love Tacomas.
  7. Feb 4, 2020 at 7:56 AM
    su.b.rat
    su.b.rat broken truck
    also 34 inseam with long arms. in a MT so need my leg/foot position correct.
    you can do it but like mentioned it is at the limit.
    when i got the truck my right thigh went numb every drive due to the flat long seat bottom pushing into the back of my thigh above the knee. i went to a custom upholstery shop and had them contour the seat bottom foam to bucket it at the rear of the seat bottom. that dropped my seating position about 1.5" and took the weight off my thigh totally. that was $200 and now my driver seat is the most comfortable seat i own and can drive for hours comfortably, and i have more head and leg room as a result. but i'm not wide and don't know if this would work for you. if you happen to be in DFW hit me up to have a sit.
    shakerhood likes this.
  8. Feb 4, 2020 at 8:00 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    I'm 5'9" and have to contort my head getting in so I don't hit it on the roof. I don't know how taller people do it.
    Skidog1 and Mr-Paul like this.
  9. Feb 4, 2020 at 8:05 AM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I'm 5'11" at 300 lbs. I'm okay with my truck... No sunroof though. Drove a truck with one and I would hit the headliner.
    Hoff likes this.
  10. Feb 4, 2020 at 8:07 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Tundruh
  11. Feb 4, 2020 at 8:11 AM
    behls
    behls Well-Known Member
    Dave
    Lehigh Valley, PA
    2017 SR5 DCSB Quicksand
    I'm 6'2 220 and overall no one loves their taco more than I do but man the size of a tundra is made for a guy like myself. I'll be bumping up in the next couple years.
  12. Feb 4, 2020 at 8:23 AM
    Grindstone
    Grindstone Requires Adult Supervision
    Test drive.
    Tacomas have gotten a little bigger since 2000. I'm 6' even, I've never had a size issue with either my old '13 without sunroof or new '20 with sunroof. Obviously, you and I are not the same person so experiences can vary.
    Test drive a Tacoma. The 2020 model year is the first with an electric driver's seat, so that may help you some.
  13. Feb 4, 2020 at 8:41 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I'm 6 foot (6'3 in heels) with a 34 inseam and i have a 2016 tacoma. I find the seat has plenty of room, doesn't cramp my legs and i don't have it pushed all the way back, i feel like it has quite a bit of room, but thats just my comfort level. Try a few different ones out and see what you think.
  14. Feb 4, 2020 at 8:50 AM
    donkeykong
    donkeykong Active Member
    Sal
    Central Coast California
    2020 MGM DCLB 4x4 TRD Offroad
    Go look at the 2020, it's the first tacoma with a powered seat that also includes lowering the seat it might be your best option if your set on a Mid-size truck.
  15. Feb 4, 2020 at 8:52 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    OT. but are some you built or just fat?
    CrippledHo likes this.
  16. Feb 4, 2020 at 9:14 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I’m 6’3”, 300 lbs, 32” inseam, most of my height is in my torso. No moon roof and I did add the front spacers on the driver seat. Some day when someone with a 2020 moves into the neighborhood I’ll get a power drivers seat.:anonymous:
  17. Feb 4, 2020 at 9:35 AM
    sublime1996525
    sublime1996525 Well-Known Member
    SL,UT
    I'm 6'1 and fit comfortably. If I was much taller I would have looked at the F150 or Ram.
  18. Feb 4, 2020 at 9:51 AM
    likeaHoss
    Awesome thanks for the replies. Yous guys pretty much confirmed my suspicions: Big guy want a big truck. Well I suppose I'll just have to go test drive a few older Tacomas. Can't afford/don't want new. If I find something that works I'll be sure to report back. Thanks again.
    su.b.rat likes this.
  19. Feb 4, 2020 at 10:06 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’ve heard the new body rams ride very nicely - May be worth looking into
  20. Feb 4, 2020 at 10:52 AM
    Merlin88
    Merlin88 $8.95 large hawaiian
    Southern Oregon
    2017 Silver SR5 V6 4x4 DCSB AT
    SSO Slimline Hybrid Bumper Smittybilt X2O 10k Wireless Winch N-Fab Rock Rails w/Removable Steps Fab Fours Premium Rear Bumper RCI Engine Steel Skid RCI Transfer Case Steel Skid RCI Transmission Steel Skid RCI Crossmember Steel Skid RCI Fuel Tank Steel Skid Pop & Lock Auto Tailgate Lock Decked Short Bed Storage System ARB OME BP-51 2” Lift Kit with ARB OME BP-51 w/adj res coil overs ARB OME BP-51 w/adj res rear shock ARB OME Differential Drop Kit SPC UCA’s w/adj Ball Joints OME Dakar Heavy Duty Leaf Packs BFG AT KO2 T/A 285/70/17 tires Ultra’s Maverick 235 17x8 wheels Full Size Matched Spare Thule TracOne Ladder Rack Toyota Matte Black Grille Smoked Amber Raptor Grille Lights Matte Black Emblems Toyota Chrome Exhaust Tip-blackout Bed Rug Tailgate Mat Optima Red Top 35 Weather Tech Side Vent Shades Weather Tech Laser Fit Floor Mats CoverKing Neosupreme Seat Covers Sabellco Tailgate Lock RedLine Quick Hood Lift Elite Subaru Tweeter’s JDMCAR liners Cupeez Scratch Protectors
    I’m 6’ even, 250, 30” inseam. I have to duck in head first or I’ll hit my head, but have gotten used to that. Plenty of head room wearing my ball caps and my seat isn't all the way back. I got a used 2017 SR5 AT and upgraded my suspension and tires for a better ride on washboarded roads. Test drive is must for sure!
