Rope Hooks - What to Do!? .... #ropehooksmatter
Discussion in '1st Gen. Tacomas (1995-2004)' started by GQ7227, Jul 1, 2019.
  1. Jul 2, 2019 at 4:42 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Nickle plating?
    Taco critter likes this.
  2. Jul 2, 2019 at 4:44 AM
    CS_AR
    Makes me think about looking for some marine grade tie downs.
    GQ7227[OP] likes this.
  3. Jul 2, 2019 at 7:13 AM
    GQ7227
    GQ7227 [OP] mw survivor
    J A Y
    i forgot to ask if you had any difficulties removing them the first time? crusty threads?
    just a standard #4 phillips is what I think is best to take them out? without stripping ... tried with a #3 but screw started stripping out so i stopped
    did the taillights need to be removed? ... was told I might have to take those out to undo them by someone that has never taken them out before
  4. Jul 2, 2019 at 7:18 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I'm glad I read that so wrong. You guys are all right.
  5. Jul 2, 2019 at 7:29 AM
    GQ7227
    J A Y
    this is not about the hooks used in Fifty shades of Grey!!
  6. Jul 2, 2019 at 8:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @GQ7227 you've been in the 3rd gen section too long now to post something like this :crapstorm:
    If it were me, I'd leave them and have them bed lined.
    Oh, and first gen best gen.
  7. Jul 2, 2019 at 8:28 AM
    GQ7227
    J A Y
    hey man i was just comparing registration fees on black tacos lol
    mine is now $99.50 but I do sorta recall what it was in its infancy and wanted to hear it from the newer taco guys to feel the tax pain
  8. Jul 2, 2019 at 8:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm in CA, where every car costs at least 400/year and trucks are nearly double that.
    I'll tell you what my 2009 Corvette registration costs later, cause I just got the DMV renewal notice 2-3 days ago.
    GQ7227[QUOTED][OP] likes this.
  9. Jul 2, 2019 at 8:30 AM
    GQ7227
    J A Y
    OMG OMG OMG
  10. Jul 2, 2019 at 1:43 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It has been some time since I messed with any industrial plating everything else has advanced so why not plating
  11. Jul 2, 2019 at 1:45 PM
    eon_blue
    Azusa, CA
    Cost me almost $300 to get my 04 registered last December. And this year I have to get the STAR smog test done, not looking forward to that.
  12. Jul 2, 2019 at 1:47 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Gotta love Ca it cost me $128.00 for 2 years in Pa
  13. Jul 2, 2019 at 2:40 PM
    GQ7227
    J A Y
    after another discussion with the LineX guy the best looking option is to take them off and get powdercoated
    until a TW fabricator wants to make a top-notch batch out of longer lasting climate-neutral material for a possible group buy?
    now just gotta see how difficult they wrench off back there without stripping
  14. Jul 2, 2019 at 3:22 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Mine wouldn't budge with just a screwdriver by hand. The heads on the flat head screws (countersink) are serrated so they grip tight. I used a #4 bit in a ratchet, the leverage of the long handle made them easy to remove without any stripping. Also used the ratchet to reinstall them tight. Threads on mine were fine, no corrosion, but I applied some anti-seize when I reinstalled them anyway. I didn't remove my tail lights, I don't see why you would even need to.
  15. Jul 2, 2019 at 3:27 PM
    #35
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Powdercoat or custom made ones? You're overthinking this way too much IMO. They're just tie down loops, why waste all that money for something that will get scratched? Just rattle can them & call it a day. Unless you have a show truck & don't use them. I use mine.
  16. Jul 2, 2019 at 3:31 PM
    #36
    Kwikvette
    Fresno County
    4 run, 2 don't
    Because #ropehooksmatter
    cornbread_wy and GQ7227[OP] like this.
  17. Jul 2, 2019 at 3:31 PM
    #37
    GQ7227
    J A Y
    was told to remove taillights to see if a box wrench or something like that was needed to hold the nut on other side, they were just guessing that these were factory installed with the sides off of the box :confused:
    i have never been able to use them for much, since they were buried deep behind plastic liner and had to finger feed any rope or heavy duty pull string, always went ghetto with dropcloth and tons of bricks!
    these 1st gen rope hooks are unique!
    I looked through the entire index of the LineX after market catalog and didn't see krap!
    mostly geared towards the detroit trucks
  18. Jul 2, 2019 at 3:35 PM
    #38
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    No need to hold the "nut" on the otherside, if you do, then either you have serious rust issues or they broke off. The "nuts" are welded to the sheet metal.
    ace_10 and GQ7227[QUOTED][OP] like this.
  19. Jul 2, 2019 at 3:37 PM
    #39
    GQ7227
    J A Y
    the salt monster better not have attacked that way up in there, been trying best to keep er clean for decades!
    zero4[QUOTED] likes this.
  20. Jul 2, 2019 at 3:41 PM
    #40
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    If it did, I don't see how you would even access the backside for the ones on the front end of the bed.
