Rotate? Balance? What do you do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pushgears, Sep 12, 2025 at 2:22 AM.
  1. Sep 12, 2025 at 3:47 PM
    jamestcurran
    jamestcurran Well-Known Member
    I just did a rotation yesterday. I have Nitto Ridge Grapplers which are non-directional, so did the Z pattern.
    A bit of a PITA as you can't just swap pairs of wheels and need 3 wheels off at a time.
    This time I just swap front-and-back on each side, then lift the rear and swapped left-to-right on the rear axle. Same effect, just two steps...
    DES2009 likes this.
  2. Sep 12, 2025 at 3:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Haven’t had an alignment since 1976. I don’t give a shit.
    Travlr, scocar and Phlogiston like this.
  3. Sep 12, 2025 at 3:50 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Every 5k. DIY so I can take a quick peak at the brakes and underneath.
    I'm rapidly approaching 60k miles on my current set of tires. Overall perfectly even wear. No doubt in my mind the longevity has been maximized (optimized) by frequent rotations. I will need new ones, however, in a few months though. They are just about worn out.
    * Alignments only when needed.
    * Ditto for re-balancing.
    My truck is butter smooth on the freeway.
    Thatbassguy likes this.
  4. Sep 12, 2025 at 4:22 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    You spend 25% more every time you buy tires but only get 20% more tread life with 5 tire.
    Not to mention the need to juggle tpms sensor ids because the trucks ecu only holds four, so that adds upfront cost of a tool.
    Again it’s what I do, but mostly for the convenience of only ever having one tire off at a time lol
  5. Sep 12, 2025 at 4:36 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    I just rotate my tires every year when I switch from my snow tires back to my summer tires.
    pushgears[OP] likes this.
  6. Sep 12, 2025 at 4:45 PM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    Seasonal won’t work for me. Since i switched to summer set I’ve done this many miles & have more than month to go. ;)
    musicisevil likes this.
  7. Sep 12, 2025 at 5:30 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    That’s some funky math, so I’ll say you actually use your spare instead of letting it rot under your truck for a decade. So you always know it’s good to go when needed.
    Also, youre juggling sensor positions when you do a normal rotation. You already need the tool.
    musicisevil[QUOTED] likes this.
  8. Sep 12, 2025 at 5:38 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I rotate mine every 5k when I change my oil. Just replaced Michelins that made it to 80k miles with perfect even wear.
  9. Sep 12, 2025 at 6:10 PM
    musicisevil
    Alaska
    2019 TRD Sport
    You don’t need a tool for a 4 tire rotation. The truck can learn the new positions of the 4 sensors it is able to store with the little button in front of your left knee, but you have to remove the ID of the new spare and add in the old spare every time you rotate if you do 5 wheels.
    The math is sound. If you rotate every 5k, you loose 5k miles on each tire after 5 rotations vs 4 tire.
    4 tire, 5 rotations = 25k per tire
    5 tire, 5 rotations = 20k per tire
    4 tire, 10 rotations = 50k
    5 tire, 10 rotations = 40k ect…
    If you made it to 100k with 4, you would have 20k more miles on each tire than if you had rotated 5. (Took me a while to post the figures correctly. I always have to draw a matrix whenever I think about this problem lol)
    Like I said I’m pro 5. There are lots of good reasons imo; easier job (arguably), lots of practice and familiarity with the spare mechanism, no seized spare hoist, tread depth on spare matches, matched wheel if anything gets messed up…
    Cost just isn’t one of them, you spend 5% more $
    AK Dudeman likes this.
  10. Sep 12, 2025 at 7:53 PM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    I have a good relationship with the local Discount Tire and they'll follow any directions you give them. I always specify the pressures I want and I also tell them to use a torque wrench only when tightening the lug nuts and they're good for it. I do oil and transmission fluid changes myself on all my cars (four of them right now) but I hope the tranny's are good now for as long as I'm on the green side of the grass. I wouldn't last long as a Jiffy Lube employee, takes me three times as long as they'd allow. Maybe it's a lot easier with the car on a lift or me in a pit, but all I have are ramps and jackstands.
    I punished myself this week and still paying for it. I replaced the rear brakes on my daughter's 2011 Corolla S as well as the rear brakes on my 2011 Tacoma. Both vehicles on jackstands, me sitting on the ground or a low stool; new drums as well as shoes. The truck was a lot harder, the tires and wheels about twice as heavy as the Corolla's. Back is killing me, but a handful of Motrin and a Rusty Nail (Scotch and Drambuie) knocks the edge off pretty well.
  11. Sep 12, 2025 at 8:00 PM
    Groan Old
    Ken
    Newton NC
    I haven't done an alignment on my Tacoma since I bought it (used) and I've put 70K on it. I doubt it's ever had an alignment since it was new (147K) but the tires wear perfectly. I did a performance 4-wheel alignment on my Miata back when I bought it and it never changed in 75K of hard driving and a half dozen sets of tires.
    Travlr and Steves104x4[QUOTED] like this.
  12. Sep 12, 2025 at 8:10 PM
    MGMDesertTaco
    I have Costco rotate and balance every 6k. BFG K03. Decent tread wear and re balancing does improve steering wheel feel.
  13. Sep 12, 2025 at 8:13 PM
    MGMDesertTaco
    They rotate every time I drive too. :rofl::burnrubber:
  14. Sep 12, 2025 at 10:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    44-16 Taco likes this.
  15. Sep 12, 2025 at 10:46 PM
    #35
    pushgears
    pushgears [OP] Well-Known Member
    2021 OR DCSB MT
    Balancing "when needed" is a slippery slope because the tires' degradation in performance occurs subtly and gradually. It's only after I re-balanced that I noticed a difference even though it felt fine beforehand.
    In a perfect world, tires would never stop rolling at a steady speed over a single surface for their entire lifespan. But parking, stop and go, off-roading, etc all contribute to uneven wear at the microscopic level that leads to [some degree of] imbalance.
  16. Sep 12, 2025 at 11:05 PM
    #36
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    If you take down your spare you can simulate a 5-tire rotation replacing one wheel or one side at a time, then when you're done just chuck the spare back upunder
  17. Sep 12, 2025 at 11:17 PM
    #37
    scocar
    scocar Patron of the Farts
    Steves104x4 likes this.
  18. Sep 13, 2025 at 6:32 AM
    #38
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    I have never heard of this strategy with a FWD car. Not saying people don’t do this but I guess I just figured everyone rotated tires in general.
  19. Sep 13, 2025 at 8:08 AM
    #39
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    I thought radials were directional and to be rotated front/back only? After reading these posts, I guess not.
  20. Sep 13, 2025 at 8:29 AM
    #40
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I've been running totaled vehicles lately, rebuilt by me after being bought cheap on insurance auctions. One of the ways I check my rebuilds is to NOT rotate tires... and honestly, I never have sweated it or done a rebalance unless I thought there was a problem and I'd already exhausted all other options. And then I usually find the problem is something else I missed.
    My present Taco had the rear end knocked out from under it by being T-boned. I had to straighten the frame rails, replace the spring U-bolts, replace a broken wheel and brake drum, and get one axle bearing replaced. The truck had 68K miles on it and is now just short of 100K and has been driven like a truck that likes being in the outback... with no issues. I put a new set of Yokohama Geolandars on it before it was repaired and they have worn evenly. I expect to get another 30K miles from them.
