Rotating tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachi13, Aug 30, 2017.
  1. Aug 30, 2017 at 2:42 PM
    Chachi13
    Chachi13 [OP] New Member
    Anthony
    2015 Toyota Tacoma TRD sport, double cab, blue
    none
    I just tried to rotate my tires and couldn't get the rear tire off. Yes, I removed all the lugs and truck was up on Jack stands. I put truck in neutral too and emergency brake was off. Is there a special tool for that big center nut or a secret I should know about?
  2. Aug 30, 2017 at 2:44 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    The wheels like to stick to the hub, and may need a little persuasion to come off.
    highriserkaiser and Breezy like this.
  3. Aug 30, 2017 at 2:47 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  4. Aug 30, 2017 at 2:49 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    There is a special tool....it's called a persuader (aka big fucking hammer).
    Beat the sidewall of the tire at 12, 3, 6, and 9 until it comes loose.
  5. Aug 30, 2017 at 2:52 PM
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
  6. Aug 30, 2017 at 2:58 PM
    corprin
    corprin Well-Known Member
    corprin
    Common in rust belt states. Galvanic corrosion between the aluminum of the wheels and steel gun/rotor cause them to stick.
    Loosen lugs and bring out the bfh as mentioned. If it's REALLY stubborn the method here is to loosen your lugs a bit (1-2 turns) and go drive a figure-eight till you hear the pop. Doesn't need to be at high speed, just a series of quick steering inputs. Once the pop happens, stop, torque the lugs, and drive back for the work.
    Larzzzz likes this.
  7. Aug 30, 2017 at 3:28 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Just beat it!!!
    Beat it!!!!
    Beat it!!!!
    In all honesty beat it like it owes you money.
  8. Aug 31, 2017 at 5:35 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    I watched a AAA guy take a stuck tire off. He beat it with a rubber mallet on the inside of the tire and it popped right off.
  9. Aug 31, 2017 at 5:39 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Yep, it's just stuck to the flat surface of the hub. Beat that thing like it owes you money.
  10. Aug 31, 2017 at 7:04 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Big center nut....:D
    Bluegrass Taco likes this.
  11. Aug 31, 2017 at 7:12 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Not to be confused with "loose nut holding the steering wheel".
