Rotational humming noise after 2/1 lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trd28, Jul 25, 2021.
  1. Jul 25, 2021 at 3:13 PM
    Trd28
    Trd28 [OP] Member
    2021 cement trd off-road
    So I got a 2” lift installed on my truck about a month ago it’s 2” in front 1” in rear I’m getting a rotational humming noise almost like a helicopter taking off lol but it’s not loud here’s what I’ve done I tried a diff drop and that made it worse so I took it off then I did the ecgs clamshell bearing on the driver side and that made the noise better but it’s still present does anyone have a idea? Has anyone else experienced this?
  2. Jul 25, 2021 at 3:23 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    No other changes just a lift?
  3. Jul 25, 2021 at 3:25 PM
    tcjacado
    tcjacado Well-Known Member
    Check the brake dust shield, sometimes they get bent when installing the lift
  4. Jul 25, 2021 at 4:19 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Might be the tires. Did you get an alignment? Have you checked your tire balance since the Lift???
  5. Jul 25, 2021 at 5:09 PM
    Trd28
    Trd28 [OP] Member
    Just the lift
  6. Jul 25, 2021 at 5:36 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    driveshaft maybe?
  7. Jul 26, 2021 at 2:50 AM
    Trd28
    Trd28 [OP] Member
    Tires have to be balanced after a lift?
    Tocamo[QUOTED] likes this.
  8. Jul 26, 2021 at 2:52 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Did you get an alignment after lift? Tires do not need to be rebalanced.
    Possibly carrier bearing drop needed..
  9. Jul 26, 2021 at 7:37 AM
    Trd28
    Trd28 [OP] Member
    I tried a diff drop and that made it worse is a carrier drop for the rear? the noise seems to come from the front end
  10. Jul 26, 2021 at 8:31 AM
    AllTacosFloat
    Boston ish
    Carrier is in the middle of your drive shaft. Yes rear. Don't use the diff drop. If you say it's coming from the front, did you get an alignment?
  11. Jul 26, 2021 at 1:30 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Ha ha, no but the lift may have made the tires noisier. You may not have noticed it before the lift.
  12. Jul 26, 2021 at 4:07 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Seriously doubt it!
