rotational slop in driveshaft...Normal???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w103tws, Aug 4, 2010.
  1. Aug 4, 2010 at 6:42 PM
    w103tws
    w103tws [OP] Well-Known Member
    So I picked up my new to me 07 sport, and noticed that every time I stop and then take off, or let off of the throttle and get back on it, I get a clunk from the driveshaft engaging. I've gotten under the truck in park, and can rotate the driveshaft about an inch. It feels like a U joint is junk, but they're all good. When I wiggle it by hand, the entire driveshaft rotates about an inch from the T-case to the rear diff. The vehicle has a certified warranty, and is covered bumper to bumper for 3mos, and pwr train for the next few years.
    Is this normal for these trucks, or should it go back to the dealer and have some warranty work done?
  2. Aug 4, 2010 at 6:52 PM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    An inch seems like quite a bit (in this case). You mean rotational movement clockwise to counter clockwise?
  3. Aug 4, 2010 at 6:56 PM
    w103tws
    Yes, rotational. (clockwise/counter clockwise)
    I may be exaggerating an inch, but it's darn close to it. you definitely know when you let off the gas, and hit it again, it feels like a U joint is shot, but they're not. I can see it rotate all the way into the T-case
    For the record, I don't get any weird vibrations or hum.
  4. Aug 4, 2010 at 6:58 PM
    drupp
    drupp Well-Known Member
    Pennsylvania
    '06 Access Cab TRD Off-Road
    An inch is not normal. Mine has rotational play of about 1/8", maybe 3/16" at both the transfer case and rear diff (none in the ujoints)....and mine has 119,000 miles on it.
  5. Aug 4, 2010 at 7:02 PM
    w103tws
    do you feel a strong "clunk" when you let off and get back on the gas, or take off from a stop?
  6. Aug 4, 2010 at 7:09 PM
    dw77x
    SE Wisconsin
    I would do some diag.
    1> Chock front wheels and lift rear tires off ground in park measure rotation
    2> On slight incline chock wheels and put in neutral measure rotation, all four tires on the ground (now you have a load on the rear end)
    I think my park paul is quite sloppy in my AT, almost to the point of a trip to the dealer. If you have that much slop in test two you have rear end issues, imo.
  7. Aug 5, 2010 at 7:46 AM
    w103tws
    I'll try that today.
  8. Oct 5, 2015 at 5:18 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    Guam
    2015 Corolla S
    Stock
