Rotational thump while under power
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KonaCoffee, Mar 20, 2024.
  1. Mar 20, 2024 at 8:28 AM
    KonaCoffee
    KonaCoffee [OP] Well-Known Member
    Massachusetts
    2019 SR5 Ext Cab, 4WD, Auto, 3.5, 80k
    I picked up this 2019 taco In my signature about a month ago. I bought it from the OO with 80k on it. Since I bought it, I’ve changed every fluid, the air filter and the sparkplugs. The two differential fluids were pretty used up. I don’t think they had been changed before. When I go down the highway especially going up a hill. I’m getting a thump thump thump from what appears to be the back of the vehicle. It’s pretty light. I took a visual inspection of everything and didn’t see anything. My rear shaft has no grease fittings. My front shaft has two grease fittings which were dry and I have since greased. All thoughts would be appreciated.
  2. Mar 20, 2024 at 8:29 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe swap the wheels around
  3. Mar 20, 2024 at 8:37 AM
    KonaCoffee
    Massachusetts
    It seems to be while under power. If I’m coasting it’s not really there? Do you think the tire/wheel could still be the issue?
  4. Mar 20, 2024 at 8:39 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Possibly a bad u-joint. I'd try to wiggle the driveshaft, especially the rear. That sounds like what my 2nd gen sounded like when one of the u-joints took a dump.
    Steves104x4 likes this.
  5. Mar 20, 2024 at 8:47 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Get the rear off the ground and try rotating while the truck is in neutral.
  6. Mar 20, 2024 at 8:53 AM
    KonaCoffee
    Massachusetts
    I moved the driveshaft and ujoint around as best I could while the truck was on the ground. I didn’t notice anything obvious.
  7. Mar 20, 2024 at 8:54 AM
    KonaCoffee
    Massachusetts
    Good idea. I’ll do that.
  8. Mar 20, 2024 at 9:02 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Has the rear diff oil ever been changed (not like it makes any difference, I guess)
  9. Mar 20, 2024 at 9:05 AM
    OldSchlPunk
    Rich
    East Central Wisco
    Third sentence in OP.
  10. Mar 20, 2024 at 9:54 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    My bad.
    OldSchlPunk likes this.
  11. Mar 20, 2024 at 10:00 AM
    KonaCoffee
    Massachusetts
    The fluid in both differentials was pretty used up. It was black and gray and not recognizable as the original product. There was a bunch of metal dust/shavings on the magnet, but no pieces of metal.
    Steves104x4[QUOTED] likes this.
  12. Mar 20, 2024 at 10:10 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I’d change the center bearing and u joints anyway at that mileage. I’m at 177k and ready to do mine again.
    KonaCoffee[OP] likes this.
  13. Mar 20, 2024 at 11:26 AM
    KonaCoffee
    Massachusetts
    I jacked up the rear end and spun everything. I felt the ujoints etc. didn’t really notice anything obvious.
  14. Mar 20, 2024 at 11:27 AM
    KonaCoffee
    Massachusetts
    Interesting. Did you change all 3 ujoints? Was it a big job? Rockauto des not have the center bearing in stock. Did you put that Ford Blue grease in the spline/yoke?
  15. Mar 20, 2024 at 11:35 AM
    KonaCoffee
    Massachusetts
    I bought it from the original owner a month ago. . He was a regular 50 year old guy that used it as a car. Trailer hitch was never used. I’m sure he took care of it. He took it to the Toyota dealership for maintenance but just did the bare minimum oil changes, etc., the truck spent some time not too far from the ocean. I’m trying to go through it and clean off any salt etc. that might have accumulated. I’m kind of thinking the salt in the air might’ve been a little tougher on differential fluid and spark plugs, ujoints etc. I’m not sure if that’s true or not or if I’m just making it up
  16. Mar 20, 2024 at 12:28 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Someone else mentioned, move the rear tires to the front, and the fronts to the rear.
    Stick to the simple stuff first. What tires, what size and what is tread wear like?
    Are the rear brakes sticking? Drive a bunch and brake a bunch downhill. Get them hot, and do the finger check on drums to see how hot they get. Maybe one is seized up?
  17. Mar 20, 2024 at 1:55 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I’ve got a reg cab and yes, I did both ends. I got about 100k out of the oe u joints. Don’t quote me but I think the joints were moog 280 (for mine, anyway)
