Roto Pax ......
Discussion in 'Off-Roading & Trails' started by UMBCrew, Aug 10, 2011.
  1. Aug 10, 2011 at 1:34 PM
    UMBCrew
    UMBCrew [OP] Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    Anybody have them or ever use them?
    are they worth it?
    what do you use them for ie. gas, water, storage, first aid?
    Are there other similar containers or mounts that are better or easier to use?
    I am only interested in using them in the bed of my truck not on an ATV or UTV side by side.
  2. Aug 10, 2011 at 3:55 PM
    H0LLYW00D
    H0LLYW00D Well-Known Member
    I have a set of Rotopax on my truck, I have a total of 8 of them, 2 are for water, 2 are for gas and 4 are storage( 3 are for my recovery gear and 1 is a first aid kit), I have them mounted to the sides of my bed rack using there locking mounts on a steel plate that was welded to the rack. I have pics on my website of them, link in sig. if you have any questions let me know.
  3. Aug 10, 2011 at 4:19 PM
    UMBCrew
    Nic
    Central Valley, CA
    sick build man i do have questions,
    where did you mount the hi-lift? shovel, axe? second battery?
    what is that on the rear bed rail next to the CB antenna?
    whats the advantage of a HAM radio over CB?
  4. Aug 10, 2011 at 4:33 PM
    H0LLYW00D
    The Hi-Lift is mounted in the bed using the same design as the 4Trac mounts, but I had my own built that are mounted to the bed rack, as I did not want to drill into the bed. The shovel and axe are mounted simular to the Hi-Lift jack on the opposite side. If you want I can email you some larger pics showing these. The second battery is mounted in the stock location using the adapter from Columbia Overland. The bed rail behind the cab has two antennas, one is for the CB radio and the other is for the HAM radio.
    HAM radio requires a license to transmit on where as CB does not, but the advantage is the HAM is way more versitle and also has much longer range. I chose to have both installed as CB is fairly inexpensive to get a decent rig and gives be the flexibility to use both and not everyone wants or has HAM radio in there truck.
    This makes me think I should goto a gallery type site as I have some 250 pics of the build, I just posted a few.
  5. Aug 10, 2011 at 4:40 PM
    UMBCrew
    Nic
    Central Valley, CA
    i didnt know they made a dual battery tray i have looked before, and looking at their site just now i cant find it.
    who is hosting your website? did you build it yourself?
  6. Aug 10, 2011 at 4:42 PM
    H0LLYW00D
    I built and host my site myself, they dont have the battery tray listed by you can call and order a kit for the second gen. I am working on adding way more pics and over hauling my site, so later today I will have 100s of pics showing the build.
  7. Aug 10, 2011 at 4:49 PM
    UMBCrew
    Nic
    Central Valley, CA
    cool looking forward to the update.
    do you like the rotopax or have you not had them long enough to really tell, i just feel like the 2 gallons for the gas is a little to little. its hard to tell the actual size of them since there are no dealers around here
  8. Aug 10, 2011 at 4:52 PM
    H0LLYW00D
    I have had them for a month or two now, I have used them to add gas to the truck on a camping trip and it is about a 1/4 tank that my 2-2gallon containers give you. my only sorta complaint about them is that the company they get to make the locking keys will not make a set that are keyed alike so I had a key ring that is organized using a belt clip and the key for the hi-lift to know which key works on which lock.
    Update: I have updated my website and there are way more pics, including pics of the Rotopax and how they are mounted and what is stored in them.
  9. Aug 11, 2011 at 12:04 AM
    UMBCrew
    Nic
    Central Valley, CA
    Midnight bump
  10. Aug 11, 2011 at 12:28 AM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    They're sturdy and will be worth every penny of yours. Unlike the older Kolpin fuel pack, the Roto Pax have more thread on the neck to prevent leaks.
  11. Dec 5, 2011 at 11:34 AM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    I have used the plate mounted to the track system in the back of my Tacoma and am very happy. As can be seen from the crappy iPhone pics, I have them mounted on either side of the bed, four of the two gallon packs. They mount securely and get awesome reviews!! They are a bit pricey but I really like the mounting system and quality of the product. Safe wheeling!!
  12. Dec 5, 2011 at 11:46 AM
    EVILSTI
    EVILSTI Well-Known Member
    Ray
    Catskill, NY
    1994 FZJ80 / 2022 Tacoma TRD Pro
    2022 Tacoma TRD Pro ......................................... 94 FZJ80 Land Cruiser Slee 6" lift kit 37" KM2s 17" procomp wheels Snorkel .......................................... SOLD: 06 TRD OFF ROAD OME Suspension lift kit with: Front OME 90000 shocks, 886 coils, top plate spacers, complete OME Dakar leaf spring packs, Front Diff drop kit, Rear N182 shocks, OME trim spacer, OME carrier bearing drop bushings, American Racing Chambers 16X8, Yokohama Geolandar A/T-S 285/75-16s (Winter tires), BFG MT KM2's 285/75-16, satoshi grille mod, TRD CAI, AP front bumper, AP skid plate, Cobra 75 WX ST CB, 2' Firestik antenna, Pioneer Avic-U310BT, Beefed Sliders, LR UCA's, Tinted Headlights, AP Rear bumper, DTLTH, Smittybilt XRC10 comp winch, Yellow top D35, pAP custom Transmission Skid ;-) , NFab spare tire holder, DT Pipe Bomb,
    I've had one mounted in my bed for a while now.
  13. Dec 5, 2011 at 12:15 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Yes, I use Gas, water and have the first aid kit version, love them, very reliable.
  14. Dec 5, 2011 at 12:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    For you guys using these with caps on , do you get any gas odour ?
  15. Dec 6, 2011 at 7:27 AM
    SoCaltaco65
    No, I usually have 4 gas, 2x water and a first aid in the bed for when we go gold prospecting, I have never had a leak or gasoline fumes/odors in 26 outtings.
  16. Dec 6, 2011 at 7:28 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    daystar is coming up with something similar and IIRC its considerable cheaper!
  17. Dec 6, 2011 at 9:42 AM
    OZ-T
    Peter North
    British Columbia
    Awesome , thanks
  18. Dec 11, 2011 at 3:03 PM
    NetDep
    Tim
    Southern Utah
    Here is a better shot of the Rotopax in the bed - and no - no odor issue.....
  19. Dec 11, 2011 at 3:04 PM
    OZ-T
    Peter North
    British Columbia
    What is the carpet bed lining material you have ? That's nice .
  20. Dec 11, 2011 at 3:04 PM
    NetDep
    Tim
    Southern Utah
    It is a BedRug...and yes, I love it!!
