Rotor and vibrations? Just read a article.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lava-road, Jul 3, 2022.
  1. Jul 3, 2022 at 7:04 PM
    Lava-road
    Lava-road [OP] Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    I was reading a few news stories, when I came across this in the news section.
    Someone purchase a use 4-runner and every few months needed new rotors.
    A tech …
    Toyota is sensitive to wheel torque. One lug nut over tighten or under tighten can cause brake vibrations.
    Also the hubs can cause the rotors to distort
    Third possible reason is over size tires.
    Just sharing this story.
    IvanhoeTaco likes this.
  2. Jul 3, 2022 at 7:10 PM
    Bishop84
    Bishop84 Well-Known Member
    I'm a toyota tech, rotors get hot spots from heat. It's that simple. So driving habits, regardless of equipment.
    Out of round can be from over torqued wheels, but is very rare. Simply because after 100ft lbs these lugs start to stretch and break.
    3rd gen 4runners had serious problems with dissipating heat. If you drove it hard or rode the brakes, it was going to need rotors.
    4th and 5th gens we don't see as many complaints.
  3. Jul 3, 2022 at 8:42 PM
    Lava-road
    2019 trd-off road
    I got a question why does my 2019 Tacoma rear passenger brakes locks up , while driving a short distances.
    My last truck wash, the rear brakes really lock hard next morning . Put in Reverse gear free the rear passenger brakes.
    Toyota told me DO NOT USE the hand brakes after a wash.
    been to the dealer 4 times, they could not find the problem.why rear passenger brakes locks up while driving. Oil/ lube cables.check the brakes.
    4th time I replace both E- cables. The problem had been reduce. Almost a month no problem, except that one truck washing. It rains a lot and I drive though muddy holes.
    2019 Tacoma TRD
    Please I like to hear what can cause this and solutions?
    In the past it happens a couple times a week. And some weeks nothing. Rains a lot here.
  4. Jul 3, 2022 at 9:04 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a vibration at 51K miles. Everything torqued to specs. I put these rotors and pads on a couple weeks ago and the vibration is gone. I never had slotted and drilled rotors before, so I am interested to see how they hold up. I never off-road, so mud and dirt is not a concern. So far I am very happy the way the truck stops.
    https://www.amazon.com/K137-Evolution-Drilled-Slotted-Ceramic/dp/B005FKS28C?pd_rd_i=B005FKS28C
  5. Jul 4, 2022 at 12:44 AM
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    I don’t know why they lock up. But my 2019 does the same thing. Two ways I’ve remedied. After a wash, drive it a couple minutes to get any water out that may have gotten in. OR, don’t use the parking break. Only happens when I used the parking brake after a wash.
  6. Jul 4, 2022 at 3:23 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    If vehicle is parked while brakes are wet a thin film of rust will form on friction surface. If park brake is applied the rust will seize brake pad/shoe and rotor/drum together. Since brake shoes have a larger surface area than pads they are more difficult to free up when moving vehicle. Brakes will sometimes be grabby or lockup prematurely until rust film rubs off.
  7. Jul 4, 2022 at 10:37 AM
    Lava-road
    2019 trd-off road
    E-brake cables also could be a problem too? After starting my Tacoma while in 4H , a short distance while driving, the rear passenger brakes will lock, reverse to free.
    it use to happen on a sharp turn, then anytime. Once I replaced the E-cables , it seems to be trouble free so far, ( only been less then two months with new e- cables). But the rear brakes did locked up hard after a washing.
