Rotor issue or tie rod issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by HeadlampRevamp, May 14, 2010.
  1. May 14, 2010 at 5:21 AM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    The other day I got my rotors turned. Now at low speeds everything is smooth when stopping, but when stopping from highway speeds it shakes worse than it did before. I took it back to the shop and they said it could be a bad tie rod. Does this sound right?
  2. May 14, 2010 at 5:28 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Pads may not have been properly bedded into the freshly cut rotors. Are the pads new too?
  3. May 14, 2010 at 6:05 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Not new, but replaced right before I bought the truck a few months back.
  4. May 14, 2010 at 6:14 AM
    shift96
    shift96 Well-Known Member
    I don't get them cut anymore. The rotors are so cheap I put new ones on when I need a brake job
  5. May 14, 2010 at 6:29 AM
    HerNameIsLucy
    RIP Lucy.
  6. May 14, 2010 at 6:32 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I do the same thing. Plus its less of a hassel. I do my own brake jobs so taking the rotors off and taking them to a shop to get turned is a pain. I know some places turn them on the vehicle but then you have to wait for the mechanic to take his sweet time. Easier to spend a few extra bucks and buy new rotors...takes little time and effort to change them.
  7. May 14, 2010 at 6:39 AM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    My 03 had the same problem, turned out to be warped rotors
  8. May 14, 2010 at 6:42 AM
    HerNameIsLucy
    RIP Lucy.
    From tirerack:
    Failure to follow these procedures may result in brake judder, excessive noise, or other difficulties in bedding-in the new brake pads. The pads need a fresh surface to lay down an even transfer film. Residue from the previous pad compound on the surface or an irregular surface on a used rotor will cause the pads to grip-slip-grip-slip as they pass over the rotor surface under pressure. The resulting vibration will cause noise and telegraph vibrations through the suspension and steering wheel. This vibration is known as brake judder or brake shimmy. This is typically caused by an uneven transfer film on the rotor surface or an uneven surface on the rotor not allowing that transfer film to develop evenly. This is often misdiagnosed as a warped rotor.
    It happens the other way around too, used pads on new or fresh cut rotors will do the same thing.
  9. May 14, 2010 at 6:46 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    What grit of sandpaper should I used to sand the pads?
  10. May 14, 2010 at 6:51 AM
    HerNameIsLucy
    RIP Lucy.
    I would think any good wet/dry emory cloth would work. You're not trying to take friction material off the pads or metal off the rotors, just the glaze off the surface.
  11. May 14, 2010 at 6:57 AM
    shift96
    I agree. Plus, I have ran into a new phenomena with alot of shops by me....They just don't give a shit and don't do things correctly. The result is I pay good money for sub par work. I don't trust that the guy who looks like Brett Micheals and smoking a cig while cutting my rotors is going to do the job correctly. I just get new ones and have less headaches.
  12. May 14, 2010 at 7:00 AM
    HerNameIsLucy
    RIP Lucy.
    Are you a 5 or 6 lugger?
  13. May 14, 2010 at 7:02 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    I agree with everyone else that it definitely sounds brake-related, and is very unlikely to be a tie-rod. Maybe it's a good excuse to step up to some Hawk or other performance pads?
  14. May 14, 2010 at 9:00 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    yeah, i should have just replaced the rotors instead of having them turned. That's my fault for not checking prices first. Hopefully they'll get it figured out and my truck won't feel like its popping wheelies when i get it back.
  15. May 14, 2010 at 9:19 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Did they cut it with an oncar brake lathe? or did they pull the rotor off and used the a regular bench lathe? Cutting with an oncar lathe is the better of the two. Have them measure runout before cutting to make sure it is the rotor.
  16. May 14, 2010 at 11:38 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Just got my truck back. They basically said I need all new brake components. Rotors, pads, calipers, and hoses. And they said that the left caliper was sticking some causing the truck to pull to the left when the brakes are applied. He said the brakes weren't being applied evenly.
  17. May 14, 2010 at 12:17 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    That sucks.... sounds cheap....
  18. May 14, 2010 at 12:38 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    where do I find cheap tacoma calipers?
  19. May 14, 2010 at 12:43 PM
    PB65stang
    Patrick
    Kansas City
    I don't know of any aftermarket calipers. They're not a part that usually wears out. I had to replace them on my Avalon and had to go through my dealer, but maybe that's because it was older. You could always try a Napa or auto parts store.
  20. May 14, 2010 at 12:50 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I might just start with the pads, rotors, and hoses and see if that helps. Is it ok to replace only one caliper, or should I replace both at the same. I think just the left one is bad.
