Rotor lug bolt holes too big?
Discussion in '1st Gen. Tacomas (1995-2004)' started by t595, Sep 22, 2012.
  1. Sep 22, 2012 at 2:47 PM
    t595
    t595 [OP] New Member
    I put a new set of aftermarket rotors on my 2003 4WD tacoma and the holes that are drilled in the rotor for the lug bolts to extend through seem to be oversized. Is this normal? The holes seem to be a mm or two larger than the lug bolt. On other vehicles they snug up nicely or there is a retainer clip to hold them in place.
    Thanks in advance.
  2. Sep 22, 2012 at 3:25 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    If you press against it and try to wiggle it up and down does it move alot? If my memory is correct the studs have a little bevel edge on them that allows the rotor to seat real nice when the lug nuts are tightened down. I understand your worry because if theres too much wiggle room the rotor will be off centered. What brand did you get and how much were they if I may ask? I took mine to machine shop to have them turned, it was $25 per rotor....maybe next time I buy new.....
  3. Sep 22, 2012 at 7:17 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    I have always had a little bit of wiggle room around the rotor studs. It tightens up when you squeeze down 6 studs at 90ft-lbs in a beveled hole. Don't worry about it.
  4. Sep 23, 2012 at 7:15 AM
    t595
    thanks
  5. Sep 23, 2012 at 9:40 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    The rotor should be hub-centric and the larger wheel stud holes won't matter.
