Rotor removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Jun 8, 2008.
  1. Jun 8, 2008 at 4:29 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Anyone know the procedure to remove a brake rotor on a 2004 PreRunner? I had a defective (Made in China) lug nut wipe out a wheel stud, so I need to get the rotor off to get the new wheel stud installed. I can't seem to locate anything in my Haynes repair manual about the removal of the rotor.
    Thanks.
  2. Jun 9, 2008 at 3:07 AM
    RedTaco02
    RedTaco02 That's an old Taco
    Manor, TX
    17 TRD
    Superhides seat covers, ARB front Bumper, Dual Batteries
    I have an 02, but I think it is the same as mine. There are a couple of pins and a 2 clip in the caliper, one on the top side of the caliper and one in the two pins on the backside, which remove the pads. maybe you don't need to remove the pads, but it will be easier to put back together. Then two bolts in the back of the caliper, which holds the caliper to the spindal. Once you get the Caliper off from the spindal, the rotor should come off. Use ZIP ties to hold the caliper up, as to not put too much tension on the lines. Get a manual from the auto store. They are cheap and explain how to do most things in decent detail. Maybe this helps.
  3. Jun 9, 2008 at 8:13 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    My Haynes repair manual does not discuss removal of the rotor at all. I can't believe it. I need to remove it to replace a wheel stud.
  4. Jun 9, 2008 at 4:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt need to take off the rotor. On the back side of the rotor, you should see on opening in the backing plate. You can push the stud out thru that opening, and install the new one. OR, just take the caliper off (2 bolts), slide the rotor off and replace the stud. :)
  5. Jun 14, 2010 at 11:54 AM
    DionysiosA76
    DionysiosA76 Captain Analyzer
    Dionysios
    Barrington, IL
    07 Taco Sport DC 6 spd-SOLD FOR CUMMINS
    Totally custom straight pipe exhaust sourced from an 01 Cummins (fabbed up by yours truly), ScanGaugeII, Westin Bull Bars, air horns, Truxedo tunneau, Black decals, Black rotors, black calipers, Secondary Air filter removal, reengineered dirtbike hauler, auxillary back up lights, blacked out tail lights, socked by Sockmonkey, blacked out hi-stop, TRD stickers (+300hp :) Owens Running Boards, Greek flag shifter, Garmin Nuvi 755w GPS, Cobra 25ltd CB with a 4' fiberglass whip... and never paid anyone nuttin to do it.
    I know this forum is like 2 years old... and the job (hopefully) is finished.
    BUT-this is for others looking for the answer
    Toyota uses these threaded holes on thier rotors and drums that accept bolts of the right size that you basically torque on enough to pop the rotor [or drum] off, installation is very simple. Just pound the damn thing on, and when you put your wheel back on and torque it correctly, it will seat perfectly.
  6. Jul 23, 2011 at 3:31 PM
    rosst
    rosst Well-Known Member
    I spent the after noon driving out really rusted tension pins... Drove to Napa for some new pins. Seems the new ones are the correct length, but smaller diameter. Is this by design? The oem pins were certainly frozen. Design change or wrong pins?
