Rotor replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pop639, Jan 18, 2012.
  1. Jan 18, 2012 at 4:15 PM
    pop639
    pop639 [OP] Well-Known Member
    Western PA
    16 SR5 DCSB 4x4
    I'm ready to replace my rotors up front but can't figure out the caliper setup. On every other vehicle I've worked on, there is a flex hose to the caliper which allows you to unbolt the caliper and suspend it out of the way. On the 2nd gens, however, there is a hardline going to the caliper. Can someone who has removed their calipers tell me how to do this without opening the system to air?
  2. Jan 18, 2012 at 4:39 PM
    over60
    over60 "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My '06 4x4 Taco has rubber, flexibke hoses to the caliper.... I changed the pads last year and had no problem just moving the caliper aside and hanging it with a wire...
    I'm not sure, but I doubt you have hard lines......OH..!!!! I think I just remembered..... there is a short hard line to the caliper; however, that line in short and connects to a flesible one on the inside of the rotor.... you just remove the clamp holding the junction and let them hang (on a wire, of course)...
    I think that's the way it was.......
    Hope this helps ya...
    Over
  3. Jan 18, 2012 at 4:40 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    this
    no need to make 2 threads though.
  4. Jan 18, 2012 at 4:46 PM
    pop639
    Western PA
    16 SR5 DCSB 4x4
    Starting a thread in this forum eliminated the chance of someone else thinking i had a 1st gen
  5. Jan 18, 2012 at 4:46 PM
    pop639
    Western PA
    16 SR5 DCSB 4x4
    thanks over60
  6. Jan 18, 2012 at 5:17 PM
    over60
    Muskoka, Ontario
    No sweat man... Hope you have fun changing them out.... When doing it, make sure you remove, clean and lubricate those pins that hold the pads on.... they get rusty and will cause premature wear on yer pads...
    Toodles...
