Rotor resurfacing
Discussion in '1st Gen. Tacomas (1995-2004)' started by lalojamesliz, Aug 14, 2018.
  1. Aug 14, 2018 at 6:06 PM
    lalojamesliz
    lalojamesliz [OP] Well-Known Member
    Ed
    02 dbl cab V6 pre-runner trd
    Tundra brake upgrade (in progress)
    Hey guys,
    When I had the new tires installed the tech was telling me these rotors are usually replaced instead of resurfaced. I've always had my rotors resurfaced and install some akebono pads
    Is this guy full of it or should I replace them even if theyll still be in spec with the resurface?
    I have 6 lug wheels and 4 piston calipers but they just dont stop like I thought 4 piston calipers would. I think they are just glazed. No noticable warpage
  2. Aug 14, 2018 at 6:14 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Have them turned, sounds like he wants to sell you some rotors
  3. Aug 14, 2018 at 6:15 PM
    1997tacomav6
    Denver
    He’s full of it, just resurface them
    :rofl:
  4. Aug 14, 2018 at 6:15 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Powerstop rotors are about $35 each. Turning costs, what? $20-$25 each? Plus a two trips to whoever will still turn them. Plus at least a four hour gap where you're waiting to be able to work on your truck. Plus a second vehicle to run the rotors around in because your truck is down.
    I replace. I have all the parts on hand, do the job without interruption, save myself hours, all at the cost of about $20. Every 70,000 miles or so?
    Rocan and outlawtacoma like this.
  5. Aug 14, 2018 at 6:18 PM
    1997tacomav6
    Denver
    Yup, I actually have two sets, one set is always read to go on and I just resurface them probably around 45,000,
    Napa is like 15.00 each
  6. Aug 14, 2018 at 7:17 PM
    lalojamesliz
    Ed
    I knew it sounded weird. I've been resurfacing rotors for the last 14 years and never heard of that but I just wanted to be sure since this is my first tacoma I've worked on since my first one I only had 2 years from new.
    Ill resurface these. As for the drums, I read here that toyota oem replacements is best but I'll probably just resurface these
  7. Aug 14, 2018 at 7:18 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    This is exactly what I do
  8. Aug 14, 2018 at 7:29 PM
    golfcarz
    golfcarz Member
    1998 & 2004 extra cab 4x4 sr5
    Maybe they can be resurfaced maybe not. They will have to be measured first. For the cost difference I just replace them. The thinner they are the more likely they will warp when they get hot. Then you still need new rotors.
    Rocan likes this.
  9. Aug 14, 2018 at 7:29 PM
    lalojamesliz
    Ed
    Where do I find the powerstop rotors guys?
  10. Aug 14, 2018 at 7:42 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Unless you have horrible braking distances or bad brake shudder, there's no need to get them replaced OR resurfaced.
  11. Aug 14, 2018 at 7:48 PM
    lalojamesliz
    Ed
    Braking isn't the best but I think I'll just leave it for now. Ac delco rotors are $32 so I'll probably go that route
    Thanks guys
  12. Aug 14, 2018 at 7:48 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I wouldn't bother with aftermarket.. I think a lot of people have trouble with them. Especially the drums. Not sure about discs
  13. Aug 15, 2018 at 12:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    In theory new pads fresh surface .
    With the cost of rotors and drums so cheap much quicker to install new .
    I don`t know any shops that still turn rotors or drums in house then you also have a bay tied up for the turn around time
  14. Aug 15, 2018 at 7:07 AM
    mwrohde
    Sugar Hill, GA
    Rockauto
