Rotor stuck on the hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teton Tacoma, May 8, 2012.
  1. May 8, 2012 at 6:34 PM
    Teton Tacoma
    Teton Tacoma [OP] Well-Known Member
    Wydaho
    2016 Off Road M/T
    Well , an easy job can get hard as a truck ages..rotor is seized on the hub. should i be concerned about using a blow torch with the wheel bearing being so close. Ive been beating on this thing with no results. 08 4wd.75k miles:help:
  2. May 8, 2012 at 6:35 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    no! they are threaded, mine were stuck to, just thread the bolt in and it comes right off!
  3. May 8, 2012 at 6:38 PM
    Teton Tacoma
    Wydaho
    2016 Off Road M/T
    you mean the lugs ?
  4. May 8, 2012 at 6:39 PM
    anthony250f
    Anthony
    San Diego, CA
    no, the rotor, look at it, there is a a threaded hole
  5. May 8, 2012 at 6:40 PM
    Teton Tacoma
    Wydaho
    2016 Off Road M/T
    Thank you!
  6. May 8, 2012 at 6:40 PM
    anthony250f
    Anthony
    San Diego, CA
  7. May 8, 2012 at 8:10 PM
    Teton Tacoma
    Wydaho
    2016 Off Road M/T
    Thanks again. Success!
  8. May 9, 2012 at 12:52 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    for the record...beating on it is not good for that bearing for sure
  9. May 9, 2012 at 9:30 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    True if bearing is loose. If its at correct preload it won't make too much difference. Then again if hammering can damage bearing what would have happen when truck is going on the road over bumps.:)
  10. May 9, 2012 at 9:47 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    For the Record that guy in the video has got to be one of the Highest functioning Crack Addicts I have ever seen. He was CRAZY FAST:eek::rofl:
  11. May 9, 2012 at 12:06 PM
    fixer5000
    massachusetts
    easy... the blow would be cushioned by the tire and not be a direct metal on metal blow..look up brinneling. impact of any kind can and will ultimately ruin a bearing of any type
  12. May 9, 2012 at 12:10 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You shouldn't be using a metal hammer to begin with. A rubber mallet would be the proper tool for helping with rotor removal if jacking holes aren't available. If you don't have a rubber mallet, holding a 2x4 against the rotor and then using a metal hammer would do the trick.
    Just a note, I would gob never seize onto the back of the new rotors. The new rotors I purchased did not have the jacking holes that the OEM ones had.
  13. May 9, 2012 at 12:14 PM
    BlueT
    NorthEast
    I dont know, it takes 20 ton press to push those bearings on the hub and they survive. I doubt anybody with 1 lb hammer can generate that kind of force. Yeah tire cushions the bumps but thats still 4000lb hitting over the wheel.
    EDIT. BTW my 20 ton press splits rotor like butter. :)
  14. May 9, 2012 at 12:21 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I did twelve years as a flat rate VW/Mazda/Honda Tech and more times than not hit the face of the rotor to pop them loose very seldom did the jack holes get used. It is a common issue after a few years, I agree with a little never seize just don't put it on the wheel studs
  15. May 9, 2012 at 12:23 PM
    Pugga
    Massachusetts
    There was actually a big debate thread as to whether or not never seize was safe to be used on the wheel studs. Got pretty heated at times. Overall, I'm with you, I don't put it on the studs although I don't believe that doing so would create an unsafe condition.
  16. May 9, 2012 at 12:28 PM
    BostonBilly
    Easton
    Ya just what I was taught. I try not to get involved in big debates, if I can help cool if not ok whatever to old to argue
  17. May 9, 2012 at 12:33 PM
    Pugga
    Massachusetts
    I hear ya, it was very informative. I was always taught the same thing so I figure if I can help it, why introduce any kind of friction modifier to the bolts that hold on the wheels :)
  18. May 9, 2012 at 12:36 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    what were the arguments? I'd put anti seize on the studs. retorque semiannually(or rotate tires twice a year) and you should be good. anti seize doesn't make the fasteners slippery to the point where it will undo istelf, it prevents them from seizing *gasp. if all the hardware is torqued to factory spec, you should be good
  19. May 9, 2012 at 12:55 PM
    BlueT
    NorthEast
    x2 I put anti size on lugs, torque them to 83 ft-lb but also check them every few hundred miles (as per Toyota manual which says check at 150 miles)
  20. May 9, 2012 at 2:18 PM
    Pugga
    Massachusetts
    The argument is that it is a friction modifier so therefore it should not be put on the wheel studs. Honestly, the thread turned into a 'well, I've always done it this way' thread.
    Personally, I put miles on fast enough where regular tire rotations are done long before the lugs seize tot he studs so I don't use it. That being said, when you torque a bolt, you're stretching the bolt a bit and you're relying on the bolt's elasticity to hold the nut in place so it shouldn't be an issue. Hell, they soak high strength bolts in oil :rolleyes:
