rotor suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fukthacubs, Oct 16, 2008.
  1. Oct 16, 2008 at 11:04 AM
    fukthacubs
    fukthacubs [OP] Well-Known Member
    wisconsin
    v6 sr5 4x4 5 speed
    what brand of rotors should i use i have ceramic raybestos pads this might be a dumb question but i figure you guys know best
    thanks alot
    doug in milwaukee
  2. Oct 16, 2008 at 11:44 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
  3. Oct 16, 2008 at 1:18 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    are these really worth 200 buks for a set there a bit pricey. for the most part this is a work truck thats not beat very often. i guess what i might be saying is im looking for the most bang for the buck, if you think this is it thank a bunch if not where do i find em.
    thank for all the help
    doug in milwaukee
  4. Oct 16, 2008 at 3:35 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Keep in mind you will want to regrease the front end parts.
    Replace all the brake fluid as well.
    Replace any cheap bearing you can..
    Then clean and adjust the rear brakes and e-brake ...
    Maybe napa has cheaper rotros...
  5. Oct 16, 2008 at 4:06 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    do you mean the wheel bearing? i am familiar with the rear breaks but it looks like the adjustment for the e break is under the box on the driver side is that it. it looks kinda self explanatory, to take apart and tighten
    thanks again
    doug in milwaukee
  6. Oct 16, 2008 at 4:18 PM
    HerNameIsLucy
    RIP Lucy.
    that's the e-brake (emergency brake). you need to adjust the brakes inside the drums.
    better yet have the drums surfaced and install new pads. keep the rears in line with the newfound stopping power of the fronts.
  7. Oct 16, 2008 at 4:33 PM
    fukthacubs
    wisconsin
    v6 sr5 4x4 5 speed
    yea i'm familiar with the drums i should have no problems with that. the linkage under the box is where i adjust the emergency break tension? it sure looked like it ?
    thanks again
    Doug in Milwaukee
