Rotora BBK (Big Brake Kit) 380 x 35mm 2 piece w/ 6 Piston Forged Aluminum Awesomeness
Discussion in 'Technical Chat' started by skygear, Mar 17, 2015.
  1. Mar 27, 2015 at 1:54 PM
    #41
    skygear
    skygear [OP]                    
  2. Mar 27, 2015 at 7:21 PM
    #42
    skygear
    skygear [OP]                    
    Flushed the stock brake fluid DOT 3 this evening. Replaced with DOT 4 fluid in Prep for the install wednesday. Another 1500 miles will be on her by then.
  3. Mar 28, 2015 at 10:43 AM
    #43
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I wish I had bigger rims so that I could do a brake upgrade but alas, no one makes anything I like the looks of.
  4. Mar 28, 2015 at 1:31 PM
    #44
    skygear
    skygear [OP]                    
    Took me forever to fund/find the set I thought was visually appealing to me in a bead lock. I'll look at the guide for wheel size vs rotor size
  5. Mar 28, 2015 at 10:53 PM
    #45
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
  6. Mar 29, 2015 at 3:44 AM
    #46
    skygear
    skygear [OP]                    
  7. Apr 8, 2015 at 8:22 PM
    #47
    skygear
    skygear [OP]                    
    Installed these and put 2k miles on them already. Everything works great. Will update this later in the week.
  8. Apr 9, 2015 at 12:18 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Oh the goodies!
  9. Apr 9, 2015 at 8:31 PM
    #49
    BadBrains
    AL
    Awesome, bet you're stoked.
    The calipers didn't look big sitting in the box. Look real beefy with your hand as reference, unless you have girly hands lol.
  10. Apr 9, 2015 at 10:00 PM
    #50
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  11. Apr 9, 2015 at 10:17 PM
    #51
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    lol thought it was 1st gen.
  12. Apr 9, 2015 at 10:21 PM
    #52
    skygear
    skygear [OP]                    
    send them an email or give them a call. You never know what kind of deal you can get ;) The site catalog is being updated and soon to be re published. Great company to work with thus far.
    Might do a 4 disk break conversion in the future. Researching rear ends right now and whats all involved in the kits out there.
  13. Apr 9, 2015 at 10:32 PM
    #53
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Would these fit with the stock 17" rims?
    Edit: Nevermind I see that info in post #10 :)
  14. Apr 9, 2015 at 10:33 PM
    #54
    memario1214
    Colton
    Missoula, MT
    I'm very interested in hearing your review. Pardon the ignorance or maybe I missed it, but are you doing fronts only?
  15. Apr 9, 2015 at 10:38 PM
    #55
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Seems like your front brakes will be amazing while the rear drums still suck. make sure you brake in a straight line. It seems safer when all the brakes suck equally.
  16. Apr 9, 2015 at 10:44 PM
    #56
    skygear
    skygear [OP]                    
    The 1st gen and 2nd gen Tacoma does not have a rear disk break setup. There is only 1 company that does the rear conversion right now. Thats the StopTech kit. They only do up to 355mm kit for the fronts and unsure on the rear kit.
    I had planned to swap out my rear end to the non e-locker as it is already for the ARB Locker. If I can find another swappable rear end with disk brakes already, it would be nice.
    already put couple thousand miles in a week on them. performed flawlessly so far.
  17. Apr 9, 2015 at 10:48 PM
    #57
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Make sure you adjust them properly, pretty sure there are some horror stories from putting discs in the rear on trucks..
  18. Apr 9, 2015 at 10:57 PM
    #58
    skygear
    skygear [OP]                    
    Proportioning valves. Read plenty on it.
    was looking at these specs for a swap. TACO vs FJ
    [​IMG][​IMG]
    Pretty damn close. Fraction of an inch off. For the REAR TRACK
  19. Apr 10, 2015 at 1:48 AM
    #59
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    These guys are about 5 minutes from my house, I think I should stop by and check em out..
  20. Apr 10, 2015 at 5:26 AM
    #60
    skygear
    skygear [OP]                    
    I would. Even if it is just to see what they are all about. From the couple people I have interactions with, they are great.
    lakerfan likes this.
