ROTORS GONE BAD!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD SPORT2016, Jun 23, 2018.
  1. Jun 23, 2018 at 8:49 PM
    TRD SPORT2016
    TRD SPORT2016 [OP] Well-Known Member
    2016 trd off road
    Hello guys,
    I just bought 2016 3rd gen tacoma (25k miles) and having problems with rotors, steering wheel shakes like hell specially on highway driving when brakes applied. Went to the dealer but obviously they denied taking responsibility. Exact same thing happened with my 2014 2nd gen tacoma as well.
    So, wanted to change rotors, what brand rotors should I go for? Any suggestions? And do I have to change the rear drums or drum pads as well? Have no knowledge about drums?
    Thanks.
    02Duck likes this.
  2. Jun 23, 2018 at 8:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Stock rotors and drums easily go 75K with normal use. If you bought it used did you or have someone check the brakes?
    BillsSR5 likes this.
  3. Jun 23, 2018 at 8:56 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    OEM rotors aren't really that bad, but if you want to look elsewhere... StopTech makes decent rotors.
    And the rear drum pads are called shoes. You don't necessarily need to change front and rear at the same time. Most of your stopping power comes from the front brakes so they take a heavier beating. Think of it as a 70/30 Front/Rear.
    outlawtacoma and hiPSI like this.
  4. Jun 23, 2018 at 9:23 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Before you throw the baby out with the bath water why not just get the rotors turned?
  5. Jun 23, 2018 at 10:06 PM
    TRD SPORT2016
    2016 trd off road
    Thank you for the info.. I do haul heavy stuff in the truck so do I need to have heavy duty rotors? May be that's why my OEM rotors are bent.
  6. Jun 23, 2018 at 10:06 PM
    TRD SPORT2016
    2016 trd off road
    Turned meaning? Machined?
    ElTaconMadre likes this.
  7. Jun 23, 2018 at 10:07 PM
    TRD SPORT2016
    2016 trd off road
    i got it inspected but they only told it has decent brakes. City driving is fine, it's just highway driving makes the wheel shake.
  8. Jun 23, 2018 at 10:08 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yes, also known as resurfacing
    shakerhood and ElTaconMadre like this.
  9. Jun 23, 2018 at 10:10 PM
    TRD SPORT2016
    2016 trd off road
    Yeah that's gonna make the rotors even more thinner, making then even more vulnerable to heat?
    Señor, r1200gs4ok and 02Duck like this.
  10. Jun 23, 2018 at 10:13 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Not exactly true. You really don’t lose thickness (maybe a mm if that) and what you do lose isn’t noticeable in any way. If you’re seriously this worried about heat dissipation, get slotted stoptech rotors and be done with it. Case closed.
    outlawtacoma and sierra141 like this.
  11. Jun 23, 2018 at 10:15 PM
    TRD SPORT2016
    2016 trd off road
    Sounds good. Thank bro.
  12. Jun 24, 2018 at 8:32 AM
    Captqc
    Tigard, OR
    As stated, turned is slang for resurfaced on a lathe, it removes a little material to smooth the rotors and remove minor warping. Under normal conditions you can do this several times and still be in the thickness specifications set by the manufacturer. If they are severely warped then replacement would probably be the best option.
    facefirst and gilligoon like this.
  13. Jun 24, 2018 at 8:35 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    How long have you had truck and how many miles since you bought it ?
    The Dealer is responsible for safety items .
  14. Jun 24, 2018 at 8:35 AM
    Bishop84
    Bishop84 Well-Known Member
    Also most run out on rotors is due to pad material embedding on the rotor surface, so you're not machining a warp out per-say. You're removing runout.
    That said if its hot spots, machining doesn't fix this. I tend to go by my experience, and on Tacoma/Tundra I only use the on-car-lathe as it prevents future runout on the trucks.
    I would suggest only OEM because I've seen every aftermarket rotor rust or fail early, you get what you pay for.
  15. Jun 24, 2018 at 8:36 AM
    Bishop84
    Brakes are wearable items, and runout is only an issue if you can prove manufacturing fault.
    Brakes are hard to warranty and they tend to bend more for loyal customers who have a history of buying the truck and servicing it from the same shop.
  16. Jun 24, 2018 at 8:51 AM
    Tacomamike mike
    Michael
    Brakes are normal (wear and tear) items.
    But if OP has had truck for short period of time, the dealer will fix the problem as it is a (safety item).
    Ask me how I know !
  17. Jun 24, 2018 at 9:07 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Impact tools on your lugnuts have been known to warp rotors (possibly even drums) with tire rotations.
    Just saying
    gilligoon, na8rboy and 2016Tacoman like this.
  18. Jun 24, 2018 at 9:16 AM
    Catfish21
    Catfish21 Well-Known Member
    Stockton, Ca.
    Trd off road 4th Gen
    get this.
    stevotivo12, 1bad2k, Tatts521 and 3 others like this.
  19. Jun 24, 2018 at 9:44 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    You may have a hard time finding someone to turn your rotors....its a dying art.
    These days people toss and replace
    sierra141, Tatts521 and Catfish21 like this.
  20. Jun 24, 2018 at 10:06 AM
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    Thank goodness we have nearly maintenence free rear drum brakes on these trucks!
    :anonymous:
