Rotors warping while towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kuks24, Dec 13, 2022.
  1. Dec 13, 2022 at 10:23 AM
    Kuks24
    Kuks24 [OP] New Member
    2013 Tacoma TRD off road
    So I had to get a different boat trailer for bass boat and now when I tow my rotors get warped and I get the wobble when I hit the brakes now. I have went through three sets of rotors and it happens after I tow. Trailer is heavier than last one but still not over towing capacity of 2013 Tacoma. Never really had to slam brakes either. Trailer has surge brakes. Is there anything I can do to truck to stop this, like I see people have upgraded brakes to Tundra brakes. Any suggestions for this.
    Thanks
    HondaGM likes this.
  2. Dec 13, 2022 at 10:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Up grade to ceramic pads?
    HondaGM likes this.
  3. Dec 13, 2022 at 10:34 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Aftermarket rotors and pads?
    Rock Lobster likes this.
  4. Dec 13, 2022 at 10:38 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Has to be. Unless he's getting them real hot and submerging the front-end at the ramp.
    I'd try changing brands. whatever those rotors are, ain't working.
  5. Dec 13, 2022 at 10:38 AM
    Sliding West
    Sliding West Mad Props!
    Dave
    Vancouver
    20 AG Pro
    SPC UCA Westcott Design Front Icon Progressive Add a Leaf Greenlane Step Slider Retrax Pro Retractable Cover Weatertech Visors EGR Hood Deflector Meso Headlight Trim Plates Meso Red Start Button Meso Vent rings Meso Blackout Start and 4X4 ring Meso Total Tail Stage 1 Meso V5 Turn signals Meso Puddle Pods Meso Overhead Hexrack Meso door handle covers VLED Vanity, License, and Plate reverse lights Tacoma OEM bed step Raptor Lights Meso Ultimate Red/White Interior Lights KTJO Grab Handle KTJO Door Pocket Lights Ice Blue Durabump Front SCS SR8 17x8.5
    After coming to a stop, if level can try taking foot off brake. Or try e-brake. Gets the pads off the rotors. Won't necessarily stop it but helps.
    Alexely999 and HondaGM like this.
  6. Dec 13, 2022 at 10:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Modify trailer to use electric brakes.
    Be eager to downshift and use engine braking.
    Can't use Tundra brakes because the Tundra is 5-lug. You can upgrade to 5th gen 4Runner brakes, which require 17" wheels and results in worse pedal feel.
  7. Dec 13, 2022 at 10:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Buy a torque wrench and ensure the trucks lugs nuts are torqued properly
  8. Dec 13, 2022 at 10:56 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  9. Dec 13, 2022 at 11:04 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    OEM pads and rotors should not be a problem unless you ride the brakes, have failing front wheel bearings, or have sticking calipers as no mileage on your post.
    Look in the Towing section for many opinions:
    The Tacoma Towing Bible | Tacoma World
    How heavy a rig do you have back there. Front rotors should never get submerged with a normal boat trailer setup unless launching off a beach in Australia.
    So I switched to front Powerstop slotted/drilled rotors and Z36 pads when towing my 5500 lb 26 ft trailer then a 3000 lb boat and never had any issues after that. Again many opinions on brands.
    Nessmuk likes this.
  10. Dec 13, 2022 at 11:24 AM
    Kuks24
    So they are aftermarket after the OEM ones warped originally.
    I never submerge the front brakes in the water.
    After last swap we used a torque wrench to put lug nuts on.
    My Tacoma is 5 lug.
    Boat and trailer I guess are about 4500+ pounds together.
  11. Dec 13, 2022 at 11:28 AM
    Kuks24
    I didn't have issue with original boat trailer, o ly started when I got new trailer after insurance and it weighs more
  12. Dec 13, 2022 at 12:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Semi-metallic or “Metallic” are usually a better choice for towing.
    They withstand heat better, and at the same time help dissipate heat.
    You can do you own research and see what’s best for you.
    Brake threads are like oil threads. We all have our own opinions.
    If you do choose to go metallic. Your wheels will get brake dust on them much more often and faster.
    It’s a trade off I suppose.
    FWIW, most of the time. The rotor isn’t warped.
    It’s pad material on/in the rotor. Or uneven rotor wear.
    Ceramic pads are more for convenience.
    95% of the time. I use ceramic.
    Because they don’t tend to develop a squeal and are cleaner.
    However, they do wear the rotor faster, but that doesn’t bother me.
    I always replace rotors with pads.
    wilcam47 likes this.
  13. Dec 13, 2022 at 12:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    How do you have a 5 lug TRD OffRoad? I'm pretty sure those only come in 6 lug. 5 lugs are typically base regular cabs, pre-runners and 4x4 trucks are 6 lug.
    If you do indeed have a 5 lug your well over the tow rating of 3500# for those trucks, only v6 trucks with the tow package are rated for 6300-6500#
    In either case you need to make sure your trailer brakes are working properly as they should be doing a significant portion of the braking on a trailer of that size.
    b_r_o, wi_taco, SR-71A and 1 other person like this.
  14. Dec 13, 2022 at 12:43 PM
    TnShooter
    Deogee
    STOCK
    I missed that part.
    I hope he didn’t get took with a sticker.
    That’s happening more and more these days.
    Also, I’ve never checked surge brakes.
    I would assume there is a way. But you’ll have to get around the spring tension.
    whatstcp likes this.
  15. Dec 13, 2022 at 12:58 PM
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
    I had my stock rotors get warped towards the end of last year, before I hit 100K miles and less than 50K miles on TRD pads. Didn't tow any before, I swapped the rotors with new OEM ones and got some Stoptech sport brake pads at the beginning of this year, and then started towing a light trailer and a 4 wheeler no more than 2x or 3x a month. My brakes got warped towards the middle of the year, and have no idea why because I don't think I slam on the brakes often.
  16. Dec 13, 2022 at 12:58 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    There should be either a reversing solenoid (the 5th pin on a 5-flat connector) that electrically locks out the brakes when you back up, and/or a manual backing pin you insert that locks the surge brakes from engaging mechanically when you back up. If you don't use either of those, it should apply the brakes as you try to back up, especially if you were backing uphill.
    Dm93 likes this.
  17. Dec 13, 2022 at 1:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Too much load on a 5 lug if you go too far or too much stopping. Way over the truck rating
    Too much brake riding by the driver is a common cause.
    The pulsation is pad material on the rotor. Clean it off and properly bed new pads. Even track cars that can make rotors glow rarely warp them. It's a slab of cast iron.
    2015WhiteOR and GilbertOz like this.
  18. Dec 13, 2022 at 3:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Adjust your trailer brakes properly or upgrade to electric brakes on the trailer. That stated, 5lugger towing a 4500lb boat... good lord.
    Dm93 likes this.
  19. Dec 13, 2022 at 3:50 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pictures of this 2013 Tacoma TRD Off-road 5-lug??!
  20. Dec 13, 2022 at 6:30 PM
    fb40dash5
    11 V6 AC 4x4
    If OP is really driving a 5 lug, then so much this ^
    I had to look for my own curiosity, since I always think of 5 lugs as a (RWD, yeah, I know...) Camry with a bed... apparently a similar era Camry has front rotors that are both thicker & larger diameter. Oof.
    Torspd and SR-71A like this.
