Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reeldealgrip, Feb 4, 2016.
  1. Feb 4, 2016 at 1:04 PM
    reeldealgrip
    reeldealgrip [OP] New Member
    Jon
    2012 Silver Tacoma TRD 4x4
    3" lift. 1-1/2" wheel spacers. Deer Plow
    I have a 2012 and I just had my break pads replaced at 62,000mi. Should I go ahead and get the rotors replaced as well?
  2. Feb 4, 2016 at 1:17 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Since you have so many miles on them, you should replace them with new pads. So if you are replacing pads replace rotors as well.
    Also remember, rule is that you always replace pads when you replace rotors.
  3. Feb 4, 2016 at 1:19 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Did the shop inspect the rotors and say they needed to be replaced?
  4. Feb 4, 2016 at 1:20 PM
    CAM37
    CAM37 Well-Known Member
    2016 Black TRD Sport
    That isn't a rule, it's a guideline. At that mileage, likely you will need rotors but if you replace pads at, say 30K miles, you may not have to. It would depend on the width of the rotors or if they have any sign of pitting or grooves.
    reeldealgrip[OP] likes this.
  5. Feb 4, 2016 at 1:59 PM
    reeldealgrip
    Jon
    I got the truck certified-used at 28,000. This is the first time I have replaced anything on the truck. Just trying to keep up with maintenance so I can get my 300k out of the truck (like I dreamed when I got it :)
  6. Feb 4, 2016 at 2:00 PM
    reeldealgrip
    Jon
    Yes, the shop recommended I replace them. "Too thin to te-surface."
  7. Feb 4, 2016 at 2:01 PM
    reeldealgrip
    Jon
    Re-surface
  8. Feb 4, 2016 at 2:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Then yes, you should replace them. As the rotors get thinner, they get hotter easier, and require more braking force to stop the same distance as new rotors.
  9. Feb 4, 2016 at 2:56 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    That's what they all say these days. Good way to turn a $200 brake job into a $500-600 job.
    CAM37 likes this.
  10. Feb 13, 2016 at 12:20 PM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Disc brakes work by changing kinetic energy to heat energy which is then sucked up by the metal mass of the rotor, then air cooled to be ready again. If you turn your rotors, you're loosing metal mass that sucks up the heat, reducing brake performance. Same holds true for slotting/drilling rotors.
  11. Feb 13, 2016 at 7:26 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    You can replace them now yourself for under $100 and peace of mind. Or possibly keep the old ones until they start warping and wearing the new pads unevenly. Better to do it now.
  12. Feb 14, 2016 at 8:12 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    If you are doing them yourself, maybe. If not, then no, you are a little too late if you have already had your pads replaced. Now you are paying twice as much for someone to rip everything apart all over again just to replace rotors.
    You should do it at the same time to avoid paying double for labor.
