Rotors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shaypay, May 18, 2024.
  1. May 18, 2024 at 8:53 PM
    Shaypay
    Shaypay [OP] Member
    Wayne
    Toyota tacomatrd sport
    I have a 2023 toyota tacoma sport 5500 km my rotors have been replaced twice I don't tow anything and drive it like an old man.Dealer says everything is fine with the truck trying to blame me.Has anybody else had this problem?
  2. May 18, 2024 at 9:00 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Why did they need replaced? That’s suspicious
  3. May 18, 2024 at 9:05 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    So you get new rotors more often than oil changes? Are these being replaced under warranty, or they convince you this is normal?Hmm...Everything is not fine.
  4. May 18, 2024 at 9:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Post the dudes name and number; I’d like to give him a ding
  5. May 18, 2024 at 9:16 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    How’d you get to the dealership twice that soon? What’s the backstory or what were the drivability issues that brought you there?
    Shaypay[OP], SoonToBeOn39s and Chew like this.
  6. May 18, 2024 at 9:27 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    If they hoodwink you again, or before they do, ask to see the old rotors and explanation/measurements.
    Shaypay[OP] likes this.
  7. May 18, 2024 at 9:52 PM
    Offroad Taco 2022
    Offroad Taco 2022 Well-Known Member
    Manny
    2022 TRD Offroad
    I thought rotors were good to about 50000+- depending on driving style and conditions
  8. May 18, 2024 at 9:54 PM
    Bishop84
    Bishop84 Well-Known Member
    It's hard to say without seeing the whole story. I dont think they are overheating but possibly theres an issue with pulsation and they are tossing rotors at the problem.
    I've seen out of round axles trick techs into changing rotors.
  9. May 18, 2024 at 10:01 PM
    Shaypay
    Shaypay [OP] Member
    Wayne
    Thanks for the replies I took it to dealer at about 3000km the brakes were pulsating replaced under warrenty.Took it again for same reason at 5500km dealer said rotors were warped again and if it happens again I have to pay out of pocket.I told them there has to be something going on rotors don't just warp.You only notice when braking at higher speeds.Anyhow I will be talking to dealer next week.Thanks for the replies
    23MGM likes this.
  10. May 18, 2024 at 10:17 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    That doesn’t sound right, they warranty the first two, but then say you have to pay for the third? Seems they should find the actual reason for rotor failure or the actual reasons for the pulsating if they’re not it.
  11. May 18, 2024 at 10:19 PM
    Offroad Taco 2022
    Manny
    2022 TRD Offroad
    Lemon law lawyers would salivate over this!!
  12. May 18, 2024 at 10:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's probably pad material transferring onto the rotor surface. Do you hold the brake pedal down hard at the bottom of hills? Or just sitting at lights? It sounds kinda counterintuitive but you should try and avoid doing that as much as possible.
    Kwikvette, Chew, pdxTacoSR5 and 3 others like this.
  13. May 18, 2024 at 10:39 PM
    Yellow03Cobra
    Yellow03Cobra Member
    Red Superchargered Taco
    Your ABS is malfunctioning. Creating heat.
  14. May 18, 2024 at 11:09 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a pulsating vibration when braking from 55-35MPH with 40K miles on my factory brakes. I put PowerStop on and very happy after 15K miles.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
    Shaypay[QUOTED][OP] likes this.
  15. May 18, 2024 at 11:27 PM
    MGMDesertTaco
    A lot of shops will turn new rotors before installing just as a precaution for out of round spec. Find a new dealer/brake shop though.
  16. May 19, 2024 at 5:08 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Agree... Very rare that rotors warp. 99.9% it's pad transfer/ build up on rotors. Must be his driving//braking habits.
    pdxTacoSR5 likes this.
  17. May 19, 2024 at 5:23 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    ^^^^ Pad transfer and flash rusting are the main causes of pulsation just like na8rboy just said. With that said my truck has 66k miles and sits all week (driving it on weekends, I always drive away with rusted rotors) and I have no rotor pulsation at all…….original pads and rotors.
    Do the new rotors actually fix your issue? My truck does have a brake vibration but it’s done it from day one and it’s from the rear……..from about 25mph to a full stop the rear brakes shudder slightly. It’s very common on these trucks, there are tsb’s but it just doesn’t bother me.
  18. May 19, 2024 at 6:06 AM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Define ‘higher speeds’. Long, downhill highway? Steep hills? For the original, first replacement, and second replacement to be doing the same thing, sounds like driving/braking habits.
  19. May 19, 2024 at 6:15 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    ...sounds like they're giving you the ole rotor rooter you know where :eek:
    Frito, na8rboy and Chew like this.
  20. May 19, 2024 at 7:08 PM
    Frito
    Frito Well-Known Member
    :rofl::rofl::rofl:
