Rotten egg smell 2012 Taco 72K
Discussion in 'New Members' started by Travlr, Jan 26, 2019.
  1. Jan 26, 2019 at 2:07 PM
    Travlr
    Travlr [OP] Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    No engine light or codes. Bad smell after freeway speeds in slow driving and down long hills under no acceleration at freeway speeds. My first thought was a bad catalytic converter, but there are four of them. Do the front ones go out first? How do you know which one is bad?
    I've also been told that a clogged fuel screen in the tank or a bad fuel pressure regulator can cause this. Any clues on diagnosing?
    I've contacted the dealer and since the truck has a salvage title they say the 80K warranty is invalidated on the cats. Is that true?
    irayfz6 and buckhuntin-tacoma like this.
  2. Jan 26, 2019 at 2:19 PM
    Travlr
    Middle'a Utah
    Thanks, nice to see and be able to mine the brains of people with experience. I'll add what I know as I can.
    irayfz6 likes this.
  3. Jan 26, 2019 at 2:21 PM
    tAcomaPueblo
    tAcomaPueblo Well-Known Member
    Virginia Beach, VA
    2017 Tacoma TRD OffRoad 4x4 DCSB
    Differential oil smells like spoiled eggs. I'd check levels and for leaking at your axles.
    irayfz6 likes this.
  4. Jan 26, 2019 at 2:24 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    From my experience bad o2 causing rich condition and then builds sulfer in the cats. Did you drive with bad o2 and then had it replaced?
    irayfz6 likes this.
  5. Jan 26, 2019 at 2:31 PM
    Travlr
    Middle'a Utah
    No codes... Wouldn't a problem O2 sensor set a code?
    JayRolla and irayfz6 like this.
  6. Jan 26, 2019 at 6:11 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...Hope you get it figured out!!
    irayfz6 and StayinStock like this.
  7. Jan 26, 2019 at 6:38 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Welcome!
    buckhuntin-tacoma and irayfz6 like this.
  8. Jan 26, 2019 at 6:42 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  9. Jan 26, 2019 at 6:42 PM
    JayRolla
    Colorado Springs
    Usually yes and I was asking if you ever had to replace the o2 previously in your ownership.
  10. Jan 28, 2019 at 6:07 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  11. Jan 30, 2019 at 2:55 PM
    Travlr
    Middle'a Utah
    I just got the truck at an auction. It was rear ended and I had to do some frame work and replace a few parts. So I have no history on the truck other than knowing it was owned by a city utility.
    I went for a long drive over the last couple of days and had no smell. Prior to that I'd put some Seafoam in at half a tank and run it down to less than a quarter tank. Maybe I'm good? I guess we'll see.
    irayfz6 likes this.
