rotten egg smell
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stephensg66, Jun 23, 2016.
  1. Jun 23, 2016 at 9:39 AM
    stephensg66
    stephensg66 [OP] Member
    gary
    I have notice a couple of times when I parked my 16 tacoma (V6 auto) that I could smell rotten eggs, kind of like old cars with bad cats. Anybody else been having the same issues. The truck has 4800 miles on it.
    PvilleJohn likes this.
  2. Jun 23, 2016 at 9:55 AM
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Check your battery usually a bad battery produces a rotten egg smell
  3. Jun 23, 2016 at 10:10 AM
    CaliforniaComa
    CaliforniaComa Well-Known Member
    Lee
    Bakersfield, Ca
    2016 Quicksand TRD Off-road 4x4
    Still to come
    I have a similar problem, I'm thinking it may be the cabin air filter being dirty. I'm going to replace it and see if that helps.
  4. Jun 23, 2016 at 10:14 AM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I believe the smell you're talking about is from the AC condenser.
    It's pretty normal after running the AC on, then turning off the AC leaving the windows up and the fan running.
    digitaLbraVo and stephensg66[OP] like this.
  5. Jun 23, 2016 at 10:33 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    :worthless:
    Scratch and sniff of course.
    TacoJonn and JayDubya like this.
  6. Jun 24, 2016 at 6:44 AM
    stephensg66
    gary
    Stan 23, that sounds odd, I have never had any of my cars Toyota's included that does that. The rotten egg smell is outside when the vehicle was just ran and pulled into my garage. Got out and the smell of rotten eggs was everywhere. As for the battery being bad, on a 2 month old vehicle?
  7. Jun 24, 2016 at 6:59 AM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Lemon law!
    Lawfarin likes this.
  8. Jun 24, 2016 at 7:26 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Typically the cause of that is gas in the cat, as you said in your first post. I would monitor it and if it happens again take it back to the dealer and have them check it for a bad catalytic, it happens.
  9. Jun 24, 2016 at 7:36 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    A bad cat converter will create a sulfur smell sometimes, but that;s usually only from bad gas being run through it. Your battery might be overcharged and boiling out, from a bad voltage regulator.
    stephensg66[OP] likes this.
  10. Jun 24, 2016 at 7:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Differential lube has a high sulfur content & smell.
    If you spot wet spots/leaks, warranty.
  11. Jun 24, 2016 at 7:45 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Really? Never knew that, good to know.
  12. Jun 24, 2016 at 9:31 AM
    stan23
    stan
    Santa Clara, CA
    Outside? Then something different then. Take it to the dealer and have them look.
  13. Jun 24, 2016 at 9:37 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Probably not driving the vehicle for long enough period of time. Engine is still in open loop (rich) mode which is dumping extra fuel on the cat. Just take the rig for a longer drive, and use the skinny pedal a little more.
  14. Jun 24, 2016 at 9:38 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    I get a funky mildewy smell if I turn off the AC/recirculator without running the blower fan to let the moisture out. I've made it a goal to flip those off and leave the blower on for a minute or two before arriving somewhere.
    andyr562, CusterFan and Paul123 like this.
  15. Jun 24, 2016 at 9:40 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    This happens in my 2014 taco as well as my 2014 tundra. Used to happen in my 2011 tundra as well. Never happened in anything but toyotas ive owned
    digitaLbraVo[QUOTED] likes this.
  16. Jun 24, 2016 at 9:40 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Always something from a '16..
    But it's probably this
  17. Jun 24, 2016 at 9:41 AM
    digitaLbraVo
    It's not isolated to only 2016s.
  18. Jun 24, 2016 at 9:46 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    This has been my experience with all new Toyota's. First noticed it back in 2003 when my buddy's mom bought a new 4Runner. It had a bad rotten egg smell after driving it. It would really smell the worst when you would get into the throttle a bit. Then we bought my wife's 2015 4Runner last year...same thing...it has the rotten egg smell after getting into the throttle. My 2015 Tacoma is also the same way.
    I have no clue what it is but you're not alone. I've even smelled it at a red light before and after looking around I noticed a new toyota with the dealer tag still on it.
  19. Jun 24, 2016 at 9:55 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Even when the vehicle is warmed up it can happen after accelerating. More unburnt fuel makes it to the cat which cools down some and then creates the sulfur/rotten egg smell. Toyotas tend to run rich anyway (helps with long term reliabiltiy) and so makes the issue more noticeable. So the Cat is not necessarily bad, although that can happen as well.
  20. Jun 24, 2016 at 10:17 AM
    stephensg66
    gary
    Thanks for the info
