Rough Country 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xTACOMAx, Jul 19, 2013.
  1. Jul 19, 2013 at 3:59 PM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    The rough country lift comes with a 3 inch spacer for the front and 2 rear shocks and 2 blocks, well does the rear shocks provide lift or is it just the blocks?
  2. Jul 19, 2013 at 4:00 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Just the blocks. What are your plans with this lift?
  3. Jul 19, 2013 at 4:07 PM
    xTACOMAx
    07 prerunner TSS
    Well I already have the lift on my truck and my truck had the factory rake and the front set 2 inchs lower in the front and now since I put that lift on my rear still sits 2 inchs higher and was wanting to take out the 2 inch block
  4. Jul 19, 2013 at 4:10 PM
    drunktaco
    Sage
    Southwest Va
    Well yeah you can pull the rear block out but it might have you sitting a little nose high. Are you just wanting to level your truck out?
  5. Jul 19, 2013 at 4:12 PM
    xTACOMAx
    07 prerunner TSS
    Yes and that's what I had to it I thought but it wasn't but I'm glad cause I was wanting to shocks any ways and it was the same price with or without the shocks
  6. Jul 19, 2013 at 4:12 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You could remove the blocks but if you ever haul a load or pull a trailer/boat your headlights will be pointing up into the sky. You might concider rear air bags and just raise the ass end when towing (or get a 1" aal.)
  7. Jul 19, 2013 at 4:13 PM
    xTACOMAx
    07 prerunner TSS
    * wanting new shocks
  8. Jul 19, 2013 at 4:15 PM
    xTACOMAx
    07 prerunner TSS
    Do y'all know what the measurement is from the ground to the center of the finder is on the front and back of a stock tacoma?
