Rough Country 3 inch lift?
Discussion in 'Suspension' started by r6chan, Jan 6, 2008.
  1. Jan 6, 2008 at 1:27 PM
    r6chan
    r6chan [OP] Well-Known Member
    Johnson City, TN
    2017 DCSB OR/wTech-Package
    I recently installed a 3 inch lift made by rough country and put 285/75/16 nitto all terrain grapplers on. I got the front end alligned and it still has a vibration from 30-42 mph and when i am almost stopped after braking? anyone got any info that would help or know what the cause is??
    Also I have a clearence issue with the top of my tire and the control arm and im in need for some spacers. Whats the best for the price.
    Feel free to e-mail me with any info!
  2. Jan 6, 2008 at 1:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im sure someone else will chime in on spacers, but as far as the vibration issue, you may want to get the tires rebalanced, maybe road force balanced. sounds like to me that you may have a tire not balanced correctly, or it may have slung a weight off.
  3. Jan 6, 2008 at 1:47 PM
    r6chan
    Johnson City, TN
    road forced balanced? Im not sure if i know what that is. I just got the tires on last wed, so the balancing should be fresh. Ill check to see if the weights are still on, though. The vib has been obvious since i lifted it the different tires has changed anything.
  4. Jan 6, 2008 at 5:56 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Did you have a struggle with the lift, maybe something is out of alignment, kind of tweaking the truck. That might be a vibration issue if it's not a tire thing.
  5. Jan 7, 2008 at 3:36 PM
    r6chan
    Johnson City, TN
    lift went on without a single problem? I talked to someone at rough country and they said that the rear blocks may take a while to settle in and find a good spot, so ill take his word for it but still it seems unlikely? Thanks for all the info guys, keep it coming...
  6. Jan 7, 2008 at 5:06 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    thats the most retarded thing i've heard. a rear block is a solid piece of metal and really only goes in one way. i dont see it "settling"
    Al O likes this.
  7. Jan 8, 2008 at 4:30 PM
    r6chan
    Johnson City, TN
    True, me too! his explanation was that there is a nipple that is a fraction too big and after a while it shaves itself down, supposedly? We will see. Any info will help guys!
  8. Jan 8, 2008 at 4:36 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Could it be driveline vibration from the increased angles?
  9. Jan 8, 2008 at 5:11 PM
    kenny3932
    kenny3932 Member
    north west Indiana
    TRD prerunner SR5
    2004 V-6 motor, tuff country 3" suspension lift, aftermarket wheels. custom grill insert
    I'll agree, I believe the angle in the shaft is causing the problem. Tacoma's have a problem with shaft vibration even with out a lift. Try experimenting with shimming the carrier bearing with washers. I have a 3'' lift on my Tacoma and by adding four 5/16'' washers on each side of the bearing the vibration is almost gone. good luck.
  10. Jan 8, 2008 at 8:07 PM
    L_Jackson
    L_Jackson Well-Known Member
    Houston, TX
    2007 Black Sand Pearl PreRunner Acce
    Tinted Windows, Tow Hitch, 3" Toytec Lift, American Racing Outlaw II Wheels, Cooper Discoverer 33's, Aries Bull Bar w/ (2) 5" Lights, Nerf Bars, Fog Lights as DTR Lights, Roll Bar w/ (4) 5" Lights, Sony Speakers, 2 Extra Tie Downs
    i understand that either!!!! i did the AAL, but to the best of my knowlege (but my knowlege is very little) a block is flat block that sits in flush on top and bottom.
  11. Jan 8, 2008 at 8:13 PM
    The_Hodge
    SC
    its flat for the most part, but its got the "nipple" on the bottom that sits into the plate mounted to the axle...and has a hole in the top for the "nipple" from the leaf pack assembly to fit into....
  12. Jan 9, 2008 at 3:40 PM
    r6chan
    Johnson City, TN
    where could i pick some washers up pretty cheap at?? ill def try it! A quick fix would be great, what part are you talking about shimming?
  13. Jan 10, 2008 at 3:05 PM
    kenny3932
    kenny3932 Member
    north west Indiana
    TRD prerunner SR5
    You can pick up 5/16" washers at any hardware or auto parts store. If you have a two piece drive shaft you'll see the carrier bearing in the middle section of the shaft. There are two bolts on each side. Back one bolt out about half way then remove the other one. Slip four or so washers between the bearing flange and the cross member and put the bolt in loosely then go to the other side and repeat. tighten them down and you're ready to go. try experimenting with more or less washers. Make equal on each side. Good luck!
  14. Jan 10, 2008 at 3:21 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    get your tires checked it took me going back 3 time before it was rite i cant rember where i got my spacers from but they are 1.25in thick what year taco do you have
  15. Jan 18, 2008 at 2:14 PM
    r6chan
    Johnson City, TN
    2005, i m tring to get just 1 in spacers
  16. Dec 1, 2009 at 7:38 PM
    rallsp12
    rallsp12 Well-Known Member
    Ralls
    Gadsden AL
    08 Black Double Cab 4WD
    2 pioneer 10'' subs with 1000 watt ma audio amp behind back seats, pioneer in dash avhp4100 dvd. westin bull bar painted with line-x black, 15 % tint on front windows and 5 % strip on windshield. rear window tinted 5 %. 3 inch toytec spacer in the front and 1 1/2 inch block in the rear
    so do you like the rough country lift? and does it actually lift it a good 3 inches and looks noticable?
  17. Dec 1, 2009 at 7:49 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  18. Sep 23, 2010 at 3:08 AM
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
  19. Sep 23, 2010 at 3:12 AM
    The_Hodge
    SC
