rough country 3 inch suspension lift questions
Discussion in 'Product Reviews' started by whiteboytoy05, Feb 8, 2011.
  1. Feb 8, 2011 at 10:58 AM
    whiteboytoy05
    whiteboytoy05 [OP] Member
    Florida
    05 tacoma SR5 sport
    I am looking into getting a rough country 3 inch supension lift. With that being said has anyone installed one there self. If so was it relatively easy? and how does the truck handle and ride? Also I was planning on running 33inch tires on 18inch wheels, would this give me enough room for to fit the tires with little or no trimming??
  2. Feb 8, 2011 at 11:01 AM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    Dirt king 3.5 LT kit with kings, 4 link rear with foa, 4.56 gears, Detroit and arb lockers, one piece drive shaft, armor, and some other things.
    i have it installed, i dont think it rides well at all, and it tends to jump accross the road haha. and i am rubbing with a 32 in tire. 275/55/20
    borrowedeye likes this.
  3. Feb 9, 2011 at 9:37 AM
    whiteboytoy05
    Florida
    05 tacoma SR5 sport
    Thanks Robert I appreciate the info, did you do any trimming to try and stop the rubbing? or is it not that bad?
  4. Feb 9, 2011 at 9:40 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Spacers are going to give you a pretty rough ride. You will definately need to trim some plastic to fit 33's. Some even have to chop the cab mount.
  5. Feb 9, 2011 at 3:45 PM
    Robertocritser
    Levi
    KY
    08 sport
    i havent trimmed it yet, it hasent bothered me enought. but when it comes to new tires i more than likely will to fit wider tires
  6. Feb 10, 2011 at 11:52 AM
    whiteboytoy05
    Florida
    05 tacoma SR5 sport
    Okay thanks again for the info. KPT what lift do you have?
  7. Feb 10, 2011 at 12:15 PM
    KPT
    09 Prerunner
    Bilstein 5100's @ 1.75"
    More info in my build.
    3rdGen_Taco likes this.
  8. Feb 12, 2011 at 3:41 AM
    Nate7747
    Nate7747 Well-Known Member
    Nathan
    Anchorage, AK
    SR5 Sport
    3" rough country lift, Black emblems, blacked out headlights, custom grill with grillcraft mesh grill and a FJ TOYOTA emblem, 130 watt KC off-road lights behind the grill, aFe CAI, Flowmaster 44 cat back dual exhaust, Pioneer 60wt amp, 10" sub, component speakers, and 7" touchscreen head unit, N-Fab steps coated with Rhino liner, studded 265/65R17 Hakka SUV tires for winter driving, new summer tires and wheels to come. Weather Tech floor mats.
    Rough Country says you dont need spring compressors, but its a bitch without one, it took me and a friend using a tie down to crank on the sping to get it back in place. I hate this lift and will replace it as soon as I get my tax return. You will not be able to the a proper alignment without new UCAs, and I doubt you will get the tires to fit without some trimming.
  9. Feb 12, 2011 at 6:34 AM
    KPT
    09 Prerunner
    :eek:
    Are you sure they didn't say you don't need a spring compressor for their top plate spacers, but you do for the coil spacers?
  10. Feb 12, 2011 at 7:53 AM
    Nate7747
    Nathan
    Anchorage, AK
    SR5 Sport
    Yeah, I even called them to ask a second time and they said that it was a simple install and I would not need one. They guy on the phone sounded pissed off that I would even call to ask questions. I would never buy fro them again, its a crappy kit in my opinion for what it cost. Rear blocks and shocks were strait forward though, not a single problem there other than what they say in the instructions is a 19mm nut on the U bolts is actually a 21mm, and since I didnt have anything over a 19 I had to make a trip to the store, on foot since the truck was taken apart.
    2001busa1 likes this.
  11. Oct 11, 2011 at 1:03 PM
    Taco R/C
    Taco R/C Well-Known Member
    08 Taco 3in
    3inch lift , 18" rims
    I bought this kit and really like it. Me and a friend installed it in about 6hrs in my garage. My truck aligned perfectly. I didnt have to have a coil compressor. Just removed the coil assembly put the spacer on top and put it back in...
  12. Oct 11, 2011 at 1:04 PM
    Taco R/C
    08 Taco 3in
    And i'm running 265/70R17 tires with no rubbing. That's only a 32" tire though.
  13. Apr 21, 2016 at 11:54 AM
    3rdGen_Taco
    3rdGen_Taco Active Member
    Joshua
    2016 Tacoma SR5
    hey do you know if those Bilstein 5100's will fit on a 2016 taco?
    mpock47 likes this.
  14. May 26, 2016 at 6:37 AM
    whiteghost2
    whiteghost2 Active Member
    noah
    2007 toyota tacoma prerunner crew cab
    retrofit headlights, raptor style mesh grill, super 40 muffler, 2 10" kicker subs, double din radio, tinted windows, trd carolina edition bed stickers, more to come
    im also looking into a rough country 3 inch suspension for my 07 prerunner. i talked to alot of guys and different shops and they all said it is what i need to fit 33s? does anyne have any other suggestions
    mpock47 likes this.
  15. Jun 21, 2016 at 7:46 AM
    mpock47
    mpock47 New Member
    2016 Inferno Tacoma trd off road 4x4
    None for right now. But wanting to modify.
    Stuck in between the 3" RC lift or 5100's (if they fit:fingerscrossed:) or something else if there is any. Still doing research.
