rough country 3" or pro comp 3"
Discussion in 'Suspension' started by 08yota, Dec 3, 2012.
  1. Dec 3, 2012 at 6:00 PM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    im looking for a good inexpensive 3" suspension lift for my 08 prerunner. my budget is about the price of these lifts. which one is going to be my best deal for the price they are? or is there another inexpensive lift that is better? please help!!!!!!
  2. Dec 3, 2012 at 8:02 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    bilstein 5100s
  3. Dec 3, 2012 at 8:11 PM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    I've been looking at the procomp suspension lift myself, like the price and simplicity. A lot of people complain it's pretty stiff due to the heavier coil spring rate (700 lbs I think) but most of them are just parroting what others have said, and don't actually have the lift themselves. Some who do actually have it installed like the ride, and don't mind the stiffness, others hate it. As for the rough country, I haven't looked much at it, but is it a spacer lift or coils/shocks lift? Overall, avoid blocks and spacers. As for everyone saying bilsteins, sure they are great for adding 2.5 inches up front, but it doesn't do anything for the rear and is still not a 3 inch lift.
  4. Dec 4, 2012 at 5:00 AM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    rough country has 2" lift blocks in the rear. so your saying the add a leaf is a better ride than the block? The reason i have been looking at the rough country is because it includes there N2.0 series shocks for the rear where pro comp you have to buy separately.
    rough country 3" suspension lift is $249
    procomp 3" suspension lift is $279
  5. Dec 4, 2012 at 6:04 AM
    dlooney
    Dennis
    Wilmington NC
    For that price I'm assuming you are looking at the pro comp spacer lift. Most everyone on here is going to tell you to avoid those completely, but some guys do run them with little problem. If you are doing any offroading whatsoever, don't get spacers. As far as the rear blocks go, blocks can increase your chances of axle wrap and other bad stuff that's not fun, get an AAL, it will make the back a little stiffer, but is much better.
    Also, most guys prefer replacing front shocks in a kit over back, since back shocks tend to be a little cheaper in most cases.
  6. Dec 4, 2012 at 8:15 AM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    I won't be doing much offroading. The only offroading I'm doing is hunting land roads and minor dirt roads. That's why I was looking at the spacer lift and the blocks. Also the blocks will enable me to do the lift at my shop instead of the paying somebody. And the local shops have told me that the blocks is the way to go for what I'm doing. But I don't want to get blocks even if they will risk the chance of hurting my axle.
  7. Dec 4, 2012 at 8:17 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Even if you dont off-road a lot I'd try to stay away from spacer lifts due to longevity. I'd save up a little more cash and go with a suspension lift. These trucks are awesome so might as well treat her right.
  8. Dec 4, 2012 at 3:05 PM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    What should I be looking for then? I'm still trying to stay cheap and being able to install at my shop myself.
  9. Dec 4, 2012 at 4:19 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Look at toyteclifts.com and check out some of their complete lift kits. It will give you a better idea on prices and what your options are. ;)
  10. Dec 4, 2012 at 4:41 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Don't buy both there crap
    This is the best investment better ride
  11. Dec 4, 2012 at 4:53 PM
    NINETY2
    NINETY2 Active Member
    Edmonton, Alberta
    06 DCLB TRD Sport
    OME 3" Lift (885, CB Drop, 2" non-TSB AAL) BHLM Debadged Tint allround
    OME 3"
  12. Dec 4, 2012 at 6:04 PM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    the OME toytec suspension lift kit?
  13. Dec 4, 2012 at 6:19 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    First reply nailed it. Not much more than the spacer lifts you mentioned above.
  14. Dec 5, 2012 at 5:07 AM
    08yota
    08yota [OP] Member
    cody
    gainesville,ga
    08 prerunner
    ok what exactly is bilstein 5100's? as you can tell im new to the tacoma world and lifts, well basically everything for my truck. so give me as much help and advise that you can when it comes to lifting my truck. i would rather do it right once that have to come back and replace something or fix something.
  15. Dec 5, 2012 at 5:37 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    http://youtu.be/PG1GynQEAPc
    These + 3-leaf progressive AAL = ĂĽber butt secks.
  16. Dec 5, 2012 at 10:06 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    08yota. you should give me a call at 303-255-4849 I work at TOYTEC LIFTS and my name is Julie.
  17. Aug 3, 2014 at 5:39 PM
    hishers2012s
    hishers2012s New Member
    ga
    his 2012 prerunner sr5 hers 2012 trd
    Just installed it on my 2012 2wd. No blocks in the back because I have 4 leafs. After installing and accurately measuring the levelness. My tacoma is 1/8" taller in the front. Now this is before taking it in for an aliment. So once the tiers set flat on the ground again it should be on the money.
    Now I plan on leveling my wife's TRD 2012 and will probably go with the Rough Country lift because it comes with a and a leaf her TRD only has three leaf springs instead of 4. Not to big on the blocks.
