Rough Country 3" Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bam18944, Jan 27, 2017.
  1. Jan 27, 2017 at 5:34 AM
    bam18944
    bam18944 [OP] Member
    Hi All!
    Brand new member and first time poster here. In '05 I bought an '05 Tacoma and then sold it years later. I'm now regretting it and and ready to pull the trigger on a '14 DC-OR-SB.
    The truck already has a 3" Rough Country Level/Lift kit installed which makes it look sharp, but man does it make it ride like crap. There is a rubbing/vibration feeling under the driver side, it feels like driving over rumble strips before a toll. Weird thing is if you put it in 4WD the vibration goes away. Also, when you hit a bump at speed, the entire backend bounces to the right.
    I am a daily driver, but appreciate the lift as our camping spot in the Poconos has many boulders and rocks in deep puddles trying to grab your underside. So, If I were to replace the Rough Country, but going for the same lift and level look, what would you recommend?
    Please remember I'm a newbie and take it easy on the acronyms! Need your recommendations in English please!
    Masshole_And_His_Taco likes this.
  2. Jan 27, 2017 at 5:49 AM
    Pigpen
    Dan
    Northwest Montana
    Welcome to TW!
    Is the truck a double cab, access cab, or regular cab?
    6 cylinder or 4?
    4x4 or 2wd?
    ChadsPride likes this.
  3. Jan 27, 2017 at 5:51 AM
    bam18944
    Hi Pigpen,
    Its a 6 cylinder, Double-Cab, 4WD, Off Road, Shortbed.
  4. Jan 27, 2017 at 5:57 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    New suspension will be in order. The noise you hear could be the needle bearing, which is a fairly simple fix. As far as shocks and coils? The possibilities are numerous. Depends on if you want to spend 1k or 5k.
  5. Jan 27, 2017 at 6:04 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    possible needle bearing for the vibe, telltale on that is if it goes away in 4wd, likely the needle bearing
  6. Jan 27, 2017 at 6:07 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    check in with Marie @HeadStrong Off-Road (TW Vendor, lots of other great vendors on here as well) she can coach you on lift options once you narrow it down a bit. great service, great pricing, and always free shipping (I think .... always :anonymous: )
  7. Jan 27, 2017 at 6:52 AM
    bam18944
    I forwarded the needle bearing idea to the service shop who is looking at the truck today.
    If I stay with the RC Lift, do you think the needle bearing would get screwed up again? Is there another upgrade to consider to fix the geometry or relieve stress?
    To answer spiralout463, I am not a hardcore off-roader, and won't be doing any crawling, just want to avoid some obstacles. I'd like to doctor it up for under 1K.
  8. Jan 27, 2017 at 7:08 AM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    In that case, Bilstein 5100 or 6125 should suit you well.
    Naveronski, TacoTronics and REDdawn6 like this.
  9. Jan 27, 2017 at 7:19 AM
    Pigpen
    Dan
    Northwest Montana
    East Coast Gear Supply has a bushing to replace the shitty bearing. Many of us run it.
  10. Jan 27, 2017 at 8:12 AM
    bam18944
    Thanks everyone for your input so far. I am trying to make sense of it now.
    So what I have is the Rough Country 745N2 kit which includes the N2 Shocks, Rear Blocks and Front Extensions.
    Are you recommending that I replace the needle bearing with the bushing and the N2 shocks and it should be a better experience? Should I do anything with the rear to fix the "hop"?
  11. Jan 27, 2017 at 8:13 AM
    bam18944
    Also, I think my '05 Sport had 5100's stock and I thought they were a little stiff. Any other softer rides out there?
  12. Feb 8, 2017 at 7:41 PM
    bam18944
    JimboAnz and Pigpen,
    I sent the bushing info for east coast gear supply to the dealer. At the same time they sent the truck to the toyota dealer to assess. Toyota recommended replacing the needle bearing. . . With a new needle bearing. My dealer took it back and placed the order from east coast.
    Long story short, its now my truck and driving perfectly. Thank you for your help!
    Naveronski and TacoTronics like this.
  13. Feb 8, 2017 at 7:44 PM
    TacoTronics
    TacoTronics War Eagle!
    Frankie
    Auburn, AL
    2014 V6 DCSB TRD Sport
    G4 Elite tonneau cover. Fuel Vapor 17s. Bilstein 5100s. Wheelers 1.5" Progressive AAL. AVID Sliders Line-X, Nokya Hyper Yellow Fogs, Fog Mod. Debadged, Ghost bedside decals, Line-X AVID Light Bar, ImMrYo mirror lift, Mattgecko LED bed lighting with remote, CSJumper2003's DTRL LED switchback mod, reversing, and parking. Nat's Rear Molle Panel for storage, HomerTaco grill.
    Good to hear. It's always a good feeling when problems get resolved.
