Rough Country...anyone???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Jul 13, 2017.
  1. Jul 14, 2017 at 12:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I wouldn't put off the brake line for a 2.5" lift... *Maybe* if you're mall crawling, maybe... But if you are going to articulate that rear axle, get the brake line for sure.
    The reason I suggest a 1.5 AAL and a 1" shackle (as opposed to a 2.5" or 3" AAL) is because of ride quality. The higher the lift for an ALL essentially just makes the ride stiffer (bigger arch on the spring), so a combo of leaf and shackle lifts minimizes that increase in stiffness, and you might get a little more articulation, too.
    Now, if you ended up needing all new springs because your factory ones are worn out, then yeah, you're looking at like $800-1000 minimum for the whole package. But if you're springs are shot, a spacer lift isn't going to do anything about that anyway...
  2. Jul 14, 2017 at 12:44 PM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Yeah, sorry I should have clarified that. I meant just doing a 1.5" AAL to make the 5100's fit, then doing the brake line when you add the 1" shackle.
    jbrandt likes this.
  3. Jul 14, 2017 at 2:07 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    When I did my lift on my '01 way back in 2011 or so, I got Rough Country shocks from Wheeler's. This is a suspension lift with Wheeler's 5 leafs in the back and OME 880s in the front. They ride great. This whole setup in now on my '03 because the buyer of the '01 didn't want it. Should I have the truck much longer, I will probably replace the shocks due to age.
  4. Jul 14, 2017 at 3:13 PM
    Willrox1
    Willrox1 Well-Known Member
    Will
    NC
    2002 Tacoma TRD Off-road - manual
    BFG AT KO2 31 Bilstein 5100 OME 883
    I put RC 2.5 inch leveling kit on mine over 2 months ago. It's holding up pretty good! But that's only over a short amount of time. But the only bad thing is that it made it a little bit stiffer in the back.
    taco71742 likes this.
  5. Jul 15, 2017 at 5:26 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
  6. Jul 15, 2017 at 8:25 PM
    Dubdaddy86
    Dubdaddy86 Well-Known Member
    I have an 08 GMC Z71 and a 99 Tacoma. Both have HAD Rough Country lifts. If you're just wanting to lift/level it, RC is fine. If you're rough on your equipment and really gonna get your money's worth, look elsewhere. My Z71 is my baby and I actually rarely drive it, the RC 3.5" I have on it is just fine for what I use it for. My Toyota doesn't necessarily get abused, but I bought it to hunt out of and it sees more than it's share of dirt rds and trails. I recently took the RC 2.5" off and put Toytec on it.
    I will say, I installed the RC on my GMC... by the time I got to the rear I installed the shocks and left it alone. The block that came with the kit was only 1/8" difference than the stock block. I'm glad I did. It sags just a hair, but it's hardly noticeable. Definitely wouldn't be confused with a "squatted truck." Keep this in mind. When it came time to install the RC on my Toyota, I had my buddy do it. Completely forget to mention anything about the rear... sure enough, when I went to get the truck, the shackles in the rear kept the stock "rake" of the truck. It still seemed to sag in the front, just the truck itself was another 2.5" taller.
