Rough Country lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Naidaguy, Jan 21, 2024.
  1. Jan 21, 2024 at 3:06 PM
    Naidaguy
    Naidaguy [OP] Member
    Nai
    05 Tacoma TRD Sport 6-speed manual 4x4
    Cold air intake. Doug Thorley long tube headers, custom exhaust setup to double borla mufflers.
    I am purchasing the 6inch RC lift kit, I am also getting the RC leaf springs. I am thinking of getting 2inch lift blocks in the rear. Would that be enough to match the height of the front? I am aware that the kit comes with 4 inch blocks but I think that will make the rear too high.
  2. Jan 21, 2024 at 3:26 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Leave your truck stock.
  3. Jan 21, 2024 at 3:53 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Is this a drop bracket or just spacers?
  4. Jan 21, 2024 at 6:46 PM
    TacoTuesday1
    SD CA
    Don’t know. This is a forum for upgrades and repairs, not rough country blocks
  5. Jan 21, 2024 at 6:48 PM
    Bishop84
    Bishop84 Well-Known Member
    Typically the kits level out perfectly, I encourage you to read up on here. The more you spend on a 6" lift, the better the results. So front coil overs and rear springs make for a much better experience than blocks front and rear.
  6. Jan 22, 2024 at 12:51 PM
    Naidaguy
    Nai
    Exactly what I was thinking, all I’ve found on the leaf springs were the ones from arcan. I haven’t seen any threads about the correct aal and how it makes the rear sit. I’m going with the the rc because it’s pretty affordable for me and it is a drop bracket kit, comes with new crossmembers and adjustable shocks.
