Rough Country lift.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Powder 71, Apr 12, 2020.
  1. Apr 12, 2020 at 2:19 PM
    Powder 71
    Powder 71 [OP] Member
    Randall
    Altus Oklahoma
    2017 Tacoma
    Can anyone offer in advise on Rough Country 4in lift kit? I have a 2017 TRD off Road 4x4. looking at getting it. Just would like more ground clearance while overlanding trips. any advised is appreciated.
  2. Apr 12, 2020 at 2:24 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  3. Apr 12, 2020 at 2:25 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Are you 4x4?
    Junkhead, gargamel05 and tcjacado like this.
  4. Apr 12, 2020 at 2:27 PM
    tcjacado
    tcjacado Well-Known Member
    Are you sure you want a drop bracket lift that makes you cut the cross member out of the frame and doesn't really give you more clearance than a 2.5 inch lift?
    Junkhead, Mully and deuceb like this.
  5. Apr 12, 2020 at 2:27 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you are starting from ground zero, this article has a lot of good info.
    https://www.tacomahq.com/66/tacoma-leveling-lift-kit/
    My personal opinion based on your stated goals and after doing a fair amount of research myself, but not actually deciding on a lift yet, is that a drop bracket kit is not what you want. They tend to be expensive and require some drastic modifications to your truck (cutting the frame). I suggest a coil-over kit for the front and a new leaf pack for the rear. The combo will net you about 2" of lift. You can get another 1-2" of ground clearance by upping your tire diameter to 33" or 35".
    Disclaimer: I'm just a random guy on the internet.
    44-16 Taco, Junkhead, Mully and 3 others like this.
  6. Apr 13, 2020 at 7:47 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    As a couple of the members mentioned above, I’d stay far away from any drop bracket kit.
    • Cheap kit BUT you'll probably need to have someone install it for you which isn't cheap.
    • You'll have to cut the cross member out and as mentioned above you'll have to get someone to install it for you unless you are very comfortable with metal/mechanic work.
    • Once you cut that cross member out you're pretty much stuck with that lift. It'll cost an additional amount of money to remove the lift and have someone fab a new cross member in again not very cheap.
    • If you ever plan on selling the truck in the future it'll be a difficult sell with that type of work done to it.
    With that said here are a couple of things to think about & a couple of good lift kit options.
    • What type of over landing are you planning on and how long are your trips?
    • Are you going to hit mostly forest roads? Or some 4WD Action type over landing? Or somewhere in between? That'll really dictate the amount of gear you're planning on carrying and give you an idea the what duty suspension you'll need.
    • If you aren't familiar with 4WD Action check out their YouTube channel here its worth a watch for sure
    Those are just a couple things to think about but here are a couple of lift kits that several members including myself are running and it seems like most people are happy.
    • Old Man Emu Lift Kit this is a great option and you can install it yourself in a day. Keep in mind there are different versions of this kit Medium Duty and Heavy Duty depending on the weight you are carrying ex. plate bumpers, which, bed cap, camping gear, recovery gear, etc.
    • Bilstein Lift Kit this is also a good option and again you can get it installed by yourself in a day but you'll want to look into beefing up your leaf springs. Personally I'd stay away from an add a leaf as it'll start to sag eventually and then you'll just end up buying new leaf springs anyway. So with that said look into Dekar (OME springs), Dever, etc.
    • Lastly, STAY AWAY from blocks or spacers they are cheap and will make the truck ride like a tractor and nobody wants that.
    I hope some of that is helpful.
    vanrynd, Junkhead, gargamel05 and 3 others like this.
  7. Apr 13, 2020 at 7:49 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    4WD Action is the shizz!
  8. Apr 13, 2020 at 7:52 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Please do lots of research, there's alot more to lifting these trucks than just installing a set of coilovers or spacers. Don't go with a DB lift. Good luck with your truck and welcome to TW.
  9. Apr 13, 2020 at 7:55 AM
    TRD4X4TOY
    TRD4X4TOY Well-Known Member
    2019 Toyota Tacoma TRD OFF ROAD
    I would go with 2 to 3 inch and if you really want 4 inches perhaps a 1 inch body lift... but it is tedious to install and if you pay to install its more money you have to spend. I personally did a 3/2 Ready lift (many shun this approach) and installed 285/75/16 and am perfectly happy with they way she handels on and off road.
  10. Apr 13, 2020 at 7:55 AM
    Taco505
    Alex
    New Mexico
    Haha heck ya damn entertaining
    Rockefelluh[QUOTED] likes this.
  11. Apr 13, 2020 at 8:31 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
  12. Aug 10, 2021 at 10:26 AM
    flatteneverymountain
    flatteneverymountain Member
    WA
    2017 Tacoma TRD Off-Road Inferno
    Icon Stage 3, Black Rhino Arsenal, KO3 265/75/16
    What did you decide? I’m very new to the game and acquired the RC 4” lift for my 2017 TRD Off Road at a pretty good discount before I knew what the hell I was doing. I’ve decided to hold off on installing after doing more research.
