Rough Country power steps and switch.
Discussion in '4th Gen. Tacomas (2024+)' started by Goin2drt, Oct 17, 2024.
  1. Oct 17, 2024 at 5:36 AM
    Goin2drt
    Goin2drt [OP] Well-Known Member
    I thought I would provide a separate post on this mod. I installed the E steps mostly for the wife. A local shop installed them for the retail price of them on Rough Country site so for me it was a no brainer to have them installed so can't help with that.
    However I did not want the ugly Rough Country switch mounted somewhere to turn them on and off so a member of another forum used the Tundra factory e step switch that fits in our blank spot. Part # - 84890-0C010. Then to make it easier to connect/test etc to the pins I had to research and find a company that makes a pigtail as Toyota only has it as part of a complete harness from the Tundra. After searching and contacting 15+ companies this place had one.
    www.connectorexperts.com
    Here comes the issue. What wires to connect from the 2 wires of the RC steps and the pins on the Tundra switch. I am not that electronically inclined. I first got the wiring/pin out diagram from @caribe makaira. I thought this would make it easy for someone who was electronically inclined. Nope. My local shop that installed them I tried first. No success. Then I reached out to other member that used the switch, nope he did not write it down. Then I thought ok for sure Rough Country can help right? Nope they were about worthless and kept saying they would figure it out and get back to me. Nope. I got myself a digital thingmajig. I started testing every combination that you could and finally, bingo. Success so I thought I would share the wires to use.
    On the switch you use wire 5 and wire 3. The RC wires are not color coded so you have to just try each way so that when connected property the "off" will keep the steps in and not deployed. If you do it backwards it is fine it just has the steps working in the "off" position so you switch them and you are good.
    End of the day the mod is not cheap, $180. However I like the factory look way more than the aftermarket switch look. Cheers.
    Switch.jpg pin out.jpg pigtail.jpg IMG_9309 (1).jpg IMG_9313.jpg IMG_9311.jpg
    Stevie17, IdahoYota and Dirty Harry like this.
  2. Oct 17, 2024 at 7:23 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Very clean!
  3. Oct 17, 2024 at 11:04 AM
    caribe makaira
    Caribbean, Puerto Rico
    So what wires went where?
    Stevie17 and Jakerou like this.
  4. Oct 17, 2024 at 11:05 AM
    Goin2drt
    Wires 5 and 3 connected to the two wires from the steps.
    Stevie17 likes this.
  5. Oct 17, 2024 at 1:45 PM
    caribe makaira
    So AUTO and OFF function then?
  6. Oct 17, 2024 at 2:08 PM
    Goin2drt
    Yes that is correct.
    Stevie17 and caribe makaira like this.
  7. Oct 17, 2024 at 2:12 PM
    caribe makaira
    You going to add step area illumination or is that already included in the purchase?
  8. Oct 17, 2024 at 2:34 PM
    Goin2drt
    Already included.
  9. Oct 17, 2024 at 2:40 PM
    caribe makaira
    Only come on when door opens? or unlock?
  10. Oct 17, 2024 at 2:52 PM
    Goin2drt
    Yeah they are lights that RC provides with the steps and when they are deployed they light up.
  11. Oct 17, 2024 at 3:26 PM
    FlyFisher1
    FlyFisher1 Well-Known Member
    NJ
    Did you have any issues putting the switch in the panel? Also what connector did you get from Connector Experts?
  12. Oct 17, 2024 at 3:34 PM
    caribe makaira
    Yes I read that. But do they deploy (light up) at unlock (door lock) or at opening door?
  13. Oct 17, 2024 at 4:23 PM
    Goin2drt
    I just sent them a pic of the end of the Tundra switch. They did not have a specific part#
    oh sorry. They light up at door open when the steps deploy.
  14. Oct 17, 2024 at 4:54 PM
    caribe makaira
    :hattip:
    :(Bummer, I thought they'd be tied to the unlock feature. Like illuminate at night BEFORE you get to the Taco. Not that it can't be fixed:burp:
  15. Oct 17, 2024 at 7:25 PM
    caribe makaira
    Like so:
    Purchase the connectors, assemble a T harness. Intercept the door Lamp with assembled T harness. Route wires to door boot then floor sill, then to cab floor access plug. Then to outer cab side area to added LED bar to illuminate ground when unlock is selected.
    L10 same on Passenger's side door.
    @daveeasa
    @Puppypunter
    Stevie17 and daveeasa like this.
  16. Oct 17, 2024 at 8:28 PM
    caribe makaira
    If route is too complicated, then use footwell illumination LED connector(s) for same feature. They use same connectors as the door LED.
  17. Oct 20, 2024 at 9:47 PM
    Tdkrum5
    Tdkrum5 New TRD OR for me.
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    Thanks for all your work on this.
    Goin2drt[OP] and Stevie17 like this.
  18. Oct 20, 2024 at 9:58 PM
    caribe makaira
    Did you get'r done?
  19. Oct 21, 2024 at 6:37 PM
    Tdkrum5
    Ted
    2024 TRD OR
    No yet need to find the switch and harness.
  20. Oct 21, 2024 at 7:19 PM
    caribe makaira
    Switch - Toyota (84890-0C010) (#19)
