Rough Country Speedometer Calibrator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alwaysHI, Nov 5, 2018.
  1. May 6, 2019 at 9:28 PM
    #61
    hellaflushca
    hellaflushca @truck_norriz
    Whats up TW!
    Thanks to @Synergy001 I pulled the trigger on the Rough Country Speedo Calibrator
    Here are my notes.
    1. Easy to install if you don't have an expedition essentials TPAM mount, if you have TPAM, it makes install a little bit longer.
    2. Confirmed as mentioned in previous replies. Same as hypertech. I actually used Hypertech's Firmware on their site vs Rough Countries and it worked.
    3. Will work with certain types of windows operating systems ( so if it doesn't download or you have error codes, if you cant solve it, try another computer and it might work, just depends on the operating system)
    4. DO NOT INPUT YOUR NEW GEAR RATIO!!! the system is only made to work with tire size, whether you put the tire size or the exact inches. If you put that you went from stock Gears ( 3.909 ) to (4.88 or 5.29), it will cause inaccurate readings. I went down the highway 2 times before i realized the fix.
    SO LEAVE THE GEAR RATIO ALONE!
    5. For my truck (2016 Limted DCSB) my stock tire size was 265/60/18. I was told if you put 265/75/16 * a more accurate stock size * it will actually read even more accurate.
    6. Leave your USB programming cable on the module and run it down to the side of the fuse box, or if you have a Longer USB Cable run it down the left side ( please make sure you don't interfere with your steering and adjustable column ) This will allow you to hook it up to your computer on its own or via extension and make any software updates without taking your whole dash off again.
    Anyway's for reference I have posted my IG live video via @truck_norriz below.
    MY verdict, for $150 dollars, or the slightly more expensive hypertech version, this is extremely worth it.
    Cheers TW
    IG VIDEO
    https://youtu.be/2rguaCVRj9A
    DoulosXP, Brostjoe, Ctupton and 5 others like this.
  2. May 6, 2019 at 11:04 PM
    #62
    alwaysHI
    alwaysHI [OP] Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Wicked!! Thanks for chiming in for all of us!
    hellaflushca likes this.
  3. May 6, 2019 at 11:18 PM
    #63
    hellaflushca
    I was actually fine without it. Then California’s gas prices went above 4 bucks lol so I figured better time than ever
    Synergy001 likes this.
  4. May 7, 2019 at 12:42 PM
    #64
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    Will this correct the mpg meter as well as odometer? Or just speedometer?
  5. May 7, 2019 at 1:48 PM
    #65
    buntcake
    buntcake Well-Known Member
    Booboo
    2020 TRD OR Cement
    Sounds like from the other posters' research this doesn't change what the ECU sees, meaning that it only adjusts the speedo. From what I understand, that means that ODO and MPG meters will be unaffected and still inaccurate.
    If anyone knows of a system that can change data fed to the ECU that would be awesome.
  6. May 7, 2019 at 2:01 PM
    #66
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I know nothing about this Rough Country unit except from what I've read on TW. It seems they are just putting their name on the Hypertech calibrator and selling it for less. Having said that, I own a Hypertech and can tell you for sure that it does affect the speedometer, odometer and shift points - so I will assume that it does indeed also affect the MPG meters. Keep in mind, stored data will not change after the install, but newly recorded data should be accurate.
    http://www.hypertech-inc.com/InlineSpeedometerCalibrator.aspx
    Aldo98229 and Deucer01 like this.
  7. May 7, 2019 at 2:54 PM
    #67
    buntcake
    Booboo
    2020 TRD OR Cement
    How can you say that for sure? Tico tested the numbers using tech stream and saw the ECU numbers varied from the adjusted speedo reading. The ODO and MPG calc uses the ECU numbers.
  8. May 7, 2019 at 3:02 PM
    #68
    mlr69
    South Carolina
    I keep a spreadsheet on all my vehicles, the odometer and gallons are recorded every time I get gas. Before Hypertech, the numbers were off, after Hypertech, the number are back to accurate. My numbers also match my GPS app. Don't know what else to tell you.
    C41n, Brostjoe and Deucer01 like this.
  9. May 7, 2019 at 3:03 PM
    #69
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Will this work on 2019 Tacomas?
    Last I saw on Hypertech’s own website, they still hadn’t broken the code on the 2019s.
  10. May 7, 2019 at 3:06 PM
    #70
    mlr69
    South Carolina
    Same thing happened to me on my 2018, their website site only went up to 2017. I talked to them and they said they were working on 2018. Sure enough, a couple months later, 2018 was available, and a software update was applied to make it work properly. I will assume their engineers are working on a 2019 update, but I don't know - give them a call.
    Deucer01 and Aldo98229[QUOTED] like this.
  11. May 7, 2019 at 3:20 PM
    #71
    Aldo98229
    Aldo
    If this programmer adjusts the speedo, odo and transmission shift points, then it does the same thing as the AEV ProCal programmer for Jeep Wranglers.
  12. May 7, 2019 at 3:28 PM
    #72
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Also, Rough Country has a 30 day full refund policy so nothing to loose if not as described.
    L-SCHLEGS likes this.
  13. May 15, 2019 at 4:52 PM
    #73
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    Just installed tonight. Used 30.6” for stock size and used tiresize.com size (34.6”) for new tires. It’s on the money with these 35s. Seems to correct MPG reading which is something I was wanting, so I’m guessing the ODO will be accurate now too.
  14. May 20, 2019 at 10:25 PM
    #74
    Dee_Rail
    Dee_Rail Well-Known Member
    Dee
    SoCal
    '18 Tacoma Off Road 4x4
    Just finished installing mine. Few things... Discrepancy before installing the calibrator was about 4 to 5 mph difference over, gauge said 70 mph, GPS showed 74/75 mph, after install gauge said a 1 to 2 mph difference under, gauge said 74 mph, GPS showed 72/73 mph. MPG was also affected. Before install, miles down to empty showed 274 miles, after install it changed to 377 miles down to empty. o_O
    Also affected was using radar cruise control, if I set it at 70 mph, cruising speed would actually be 4 to 5 mph faster.
  15. May 21, 2019 at 5:37 AM
    #75
    mlr69
    South Carolina
    You may want to play some more with your Hypertech settings - if you have it set correctly, your speedometer should be dead on with your GPS numbers. Once you get your speedo correct, the rest (odo, mpg, shift points) will be accurate too.
    The radar cruise control numbers are not effected by the Hypertech, unfortunately that will always be inaccurate. Seems the cruise control gets it data from a different location and does not go through the Hypertech.
  16. May 21, 2019 at 12:36 PM
    #76
    Dee_Rail
    Dee
    SoCal
    How much more room is there to play with aside from changing the diameter or tire size? The 1/2 mph discrepancy is only when cruise control is used.
  17. May 21, 2019 at 12:51 PM
    #77
    mlr69
    South Carolina
    Ok sorry, I must have read your post wrong - I though you said gauge said 74 mph, GPS showed 72/73 mph. If you're only 0.5 mph off then I wouldn't mess with it.
  18. Jun 18, 2019 at 10:03 PM
    #78
    hellaflushca
    Brostjoe likes this.
  19. Dec 8, 2019 at 2:43 PM
    #79
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I just bought and ordered this for my 2019 Tacoma, I havn't installed yet. after reading some posts I hadn't realized this was only for 16-18 tacomas. Do you guys think it will work on my 2019 or am I wasting my time? are there 0 options for a 2019 and I guess now 2020 Tacoma to correct the speedometer for larger tires?
  20. Dec 8, 2019 at 2:50 PM
    #80
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    are you saying that the radar cruising speed is now correct after installing the calibrator. or it still is not working correctly?
    C41n likes this.
