Rough Country Speedometer Calibrator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alwaysHI, Nov 5, 2018.
  1. Mar 9, 2023 at 10:30 PM
    #141
    alwaysHI
    alwaysHI [OP] Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Wow. Glad to see this thread is still alive!
    I ran then hid mine behind the left kick panel
    bullpen58[QUOTED] likes this.
  2. Mar 9, 2023 at 10:39 PM
    #142
    erok81
    erok81 Well-Known Member
    Imposter
    I live in CA and ordered it right off their site. :notsure:
  3. Mar 9, 2023 at 10:41 PM
    #143
    erok81
    Imposter
    When you install it just leave the usb plugged in and find somewhere to tuck it so you can reach later. Really easy once you have it apart.
  4. Mar 10, 2023 at 2:24 AM
    #144
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Its better to leave it plugged in behind the speedometer cluster so the cord can reach over to a lap top when making adjustments. My tuner who did my KDMAX tunes got mine dialed in perfect when I went to 285s.
  5. Oct 26, 2023 at 2:27 PM
    #145
    Tadao
    Tadao New Member
    2018 Tacoma Off-Road
    Installed the Rough Country speedo calibrator on my 2018 Off-Road with 285/70R/17s. It immediately and accurately corrected the speedo. It did NOT restore the OEM shift points as advertised by Rough Country. I'm not surprised and plan to get the OTT anyway, but be advised if you were counting on that. I haven't yet figured out whether it corrected the odometer, or not. Does anyone know where the odometer reading is taken?
    Update: I confirmed that the speedo calibrator DID also correct the odometer reading. It also corrected the estimated MPG reading. It appears that my 3" lift + 285/70R/17's did NOT appreciably reduce my gas mileage. (~16mpg combined city / highway; ~20mp highway). Since installing the oversized tires, I've been driving in ECT/PWR mode which helps get the shift points closer to stock given the slightly taller gearing from the oversized tires.
    Side note: There is a feature in the GPS settings to recalibrate the GPS to new (and different) tire size. Detailed Navi Settings / Calibration / Tire Change. The notes in manual say:
    This navigation system uses tire turning
    data and is designed to work with factory-
    specified tires for the vehicle.
    Installing tires that are larger or smaller
    than the originally equipped diameter
    may cause inaccurate display of the current
    position. The tire pressure also
    affects the diameter of the tires, so make
    sure that the tire pressure of all 4 tires is
    correct.
    I have no idea whether this has any effect beyond the GPS mapping system. Does anyone know?
  6. Dec 11, 2023 at 1:28 PM
    #146
    Gumby
    Gumby Well-Known Member
    Washington State
    SR5
    This might be dumb question, but what's the difference between in-line speedometer calibrator modules (like the RC or Hypertech that are discussed in this thread) and something like the calibration programmers that Hypertech sells? It seems like the programming unit has additional features like the ability to read and clear DTCs and potentially to also provide additional tuning functions? The price for the programmer is around $205 on their website whereas the RC in-line module is $160 and the Hypertech module is $250. Is there a reason to prefer the in-line module?
  7. Dec 11, 2023 at 6:35 PM
    #147
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    My guess is the "calibration programmers" are not compatible with the Tacoma. Check their website further by putting in your vehicle specifics into their product finder. I put my specifics in and the only Hypertech product returned was the in-line unit.
    musicisevil likes this.
  8. Dec 11, 2023 at 6:49 PM
    #148
    Gumby
    Washington State
    SR5
    Ahha, that would make sense. A teacher once told me there are no dumb questions, only dumb people who ask questions. I think I just proved his point.
  9. Dec 11, 2023 at 8:32 PM
    #149
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Easy mistake to make. If it makes the decision any easier, the RC is the same thing as the hypertech just in different packaging at a lower price point. I went RC and when I downloaded the software and drivers it was all labeled hypertech
  10. Feb 1, 2024 at 6:27 AM
    #150
    Acwood
    Acwood Well-Known Member
    Alex
    Atlanta, GA
    2023 TRD Sport 4x4
    Bilstein 5100 2/1 level, diode dynamics SS3 sport fogs, form taillights, interior chrome delete and LED interior
    I just got the RC inline Speedo Calibrator, but I have a '23 TRD Sport. When I plugged the module in to the USB and ran the application on my computer, it does not allow me to choose a '23 Toyota, in fact, the only options available for 2023 are Jeep and Ram. I was able to go down to the 2021 Model year and Toyota appeared, thanks to the suggestion of VaToy from here. Has anyone had this issue and had to use a different year than the year of their exact vehicle?
    VaToy likes this.
  11. Feb 1, 2024 at 6:31 AM
    #151
    mauctopa
    mauctopa Well-Known Member
    Does it also display the correct mpgs?
  12. Feb 1, 2024 at 9:34 AM
    #152
    Toycoma2021
    I don't recall that question being asked before, interesting, I don't know but I doubt it. However, I don't think most people believe the Toyota calculated estimate to begin with. I only use the getting low on fuel notice. I do wish somebody would come up with a way to correct the cruise control with a change in tire size.
    Edit: The Rough Country unit works just fine, correcting Speed display and the Cruise Control. 19 Feb 2024
  13. Feb 1, 2024 at 1:05 PM
    #153
    Acwood
    Alex
    Atlanta, GA
    2023 TRD Sport 4x4
    What is wrong with the cruise control when calibrating to bigger sizes?
  14. Feb 1, 2024 at 2:11 PM
    #154
    Toycoma2021
    The Rough Country device only changes the CANBUS signal to the speedometer to modify the displayed MPH, nothing more. The Cruise control is independent of the Speedometer and is found somewhere else in the vehicle, still connected to the CANBUS but unaffected by the Rough Country device. In my current configuration I have to set the cruise control to 62 MPH to go 65MPH. It will get worse when I get even bigger tires. 255/85R16
    Edit: Updated unit and installed. Cruise control displayed just fine, as did the speedometer. I recommend. 19 Feb 2024
  15. Feb 2, 2024 at 7:23 AM
    #155
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    interesting. how has no one else mentioned this?
  16. Feb 2, 2024 at 8:17 AM
    #156
    Toycoma2021
    Inattentiveness, I suppose or they don’t use the cruise control much. This has been covered in other threads.
    To illustrate this quandary a bit more. I have two GPSs on the dash and an UltraGauge, the Ultra displays the CANBUS speed which is the same as the cruise control. The GPSs display the vehicle speed. The only way to make them all the same, I believe, is to alter the wheel speed sensors input to the Skid Control ECU. Toyota makes no allowance for tire change sizes, hence the box that goes behind the speedometer.
    Edit: Updated unit and installed. Cuise control displayed just fine, as did the speedometer. I recommend. 19 Feb 2024
    commbubba19 likes this.
  17. Feb 5, 2024 at 5:05 AM
    #157
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Search this thread only for "cruise" and you'll get 22 results. Everyone has their own beliefs as to why the cruise control set speed doesn't display properly.
    commbubba19[QUOTED] likes this.
  18. Feb 5, 2024 at 6:03 AM
    #158
    commbubba19
    '23 TRD PRO
    I had the hypertech on my 17 and never noticed this but also made sure it was running the current firmware. A post a few pages back mentioned that he also updated it to latest and radar cruise setting matched digital/analog speed.
    Lastly, Amazon has the Hypertech for $143 making it cheaper than the RC unit
  19. Feb 5, 2024 at 6:56 AM
    #159
    mlr69
    South Carolina
    I'm very happy with my Hypertech on my 2018. I know the cruise control will hold at whatever speed it set it at, so I don't really care that the MID shows the wrong number as long as my speedometer is correct, which it is.
  20. Feb 5, 2024 at 8:32 AM
    #160
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    Interesting about the cruise control. I have a hypertech on my 23 and the cruise works as intended. Had one on my 17 colorado and it all worked fine as well.
