Rough Country Upper Ball joint Moog replacement?
Discussion in 'Suspension' started by Tacomabro7, Feb 13, 2023.
  1. Feb 13, 2023 at 8:24 PM
    Tacomabro7
    Tacomabro7 [OP] Active Member
    2016 Red Tacoma TRD Off-Road 4x4 Automatic
    Hi-line front bumper 305/60R18 tires
    Hi Tacomaworld,
    So about 5 months ago I installed the 3.5" lift kit from Rough Country and already the upper ball joints are beginning to crack and dry rot. RC says that you MUST get a replacement from them but could I replace them with MOOG ball joints instead? I figure MOOG has much better quality rubber than what junk country uses. Which MOOG upper ball joint would work with the RC upper control arm? Thanks!!!
