Rough Country Vertex coilovers???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phil4200, Oct 2, 2020.
  1. Aug 12, 2021 at 7:39 PM
    #181
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Going the route I did is more of a cheaper way . Aal are cheap and they did exactly what I needed to do. Im happy with the results. I could have just went and spent $$$$$$$$ on a new leaf pack but I rather not experiment on $500+ leaf packs
  2. Aug 13, 2021 at 2:31 AM
    #182
    Acesolo1!
    Acesolo1! Well-Known Member
    benjamin
    2020 tacoma dbl cab 4x4 v6 sr
    n/a
    Yeah I hear that.from all my research it seems alot of leaf companies are nor holding up to what people expect tho .i hear bad reviews on just about every company which makes me nervous.one thing I am worried about tho is getting a aal that doesnt conform well with the rest of the pack .i have no idea how to find out if it will or not before apending money to find out the hard way .archive garage sells one that seems to conform well but they also suggest having 400 lbs in the bed and dsc coilovers for a better ride....dont have that kind of money right now and at most my dauly load is about 250-300..im thinking id like a aal that goes on top of the overload spring to fill ij that gap .if anyone knows of a aal that will fit in that area and conform well id appreciate it .
  3. Aug 13, 2021 at 7:14 AM
    #183
    shotgunbilly420
    Look up helwig helper springs
  4. Aug 13, 2021 at 7:22 AM
    #184
    Phil4200
    Phil4200 [OP] Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Crazy, Helwig is a small company about 5 miles away from me.
  5. Aug 17, 2021 at 1:42 PM
    #185
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Will the 3.5” work for the 2nd Gen??
  6. Aug 17, 2021 at 2:10 PM
    #186
    tclavell
    Troy
    Phoenix, AZ
    G70
  7. Aug 17, 2021 at 6:16 PM
    #187
    shotgunbilly420
    Has anyone upgraded the front springs on the 6" lift ? What weight did you choose ? What company did you go with? Right now they are 600lbs springs. I'm seeing if I can find 700lbs springs for the 6" lift .
  8. Aug 18, 2021 at 2:38 PM
    #188
    TegoTaco
    Ontario, Canada
    Well boys and girls, I ordered the 3.5” coilovers! :D
  9. Aug 20, 2021 at 9:58 PM
    #189
    Summers_Kytaco_19
    Summers_Kytaco_19 “I did that in 2wd” rdpoe
    Steven
    Independence, KY
    19 trd OR tacoma
    First test run with the Vertix.
    Little flexy flexy today
  10. Aug 22, 2021 at 8:57 PM
    #190
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    So what's the verdict on VERTEX‽ Worth it or junk?? What says you??
  11. Aug 22, 2021 at 9:08 PM
    #191
    shotgunbilly420
    So far few thousand miles with their 6" lift and loving it
  12. Aug 22, 2021 at 10:05 PM
    #192
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    Supposedly; I've read somewhere, but don't quote me on this, as I've not verified nor researched in depth, but supposedly these Vertex were designed by ex-engineers from Fox. Again, I don't know how true this is, but thought I'd throw it out there not as an FYI, but more as a maybe this could have some truth behind it?‽?
    I'll keep a look out for further posts, and keep following any VERTEX threads. Thanks again....
    shotgunbilly420 and Phil4200[OP] like this.
  13. Aug 23, 2021 at 12:19 AM
    #193
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    That would be interesting. Following
    shotgunbilly420 likes this.
  14. Aug 23, 2021 at 6:14 PM
    #194
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I've been meaning to ask.
    Are the fronts just built in spacer lifts with compression adjusters ?
  15. Aug 30, 2021 at 12:54 PM
    #195
    MauiJR808
    MauiJR808 Well-Known Member
    Jrey
    Hawaii
    2008 black tacoma 4x4
    Paint black with gold pearl with camper
    Can it handle 220lbs bumper and with winch? I love the look and th adjustable stiffness. I would love to use this on my 2nd gen tacoma. I'm ready to buy it but I want to make sure it can handle the weight in the front
  16. Sep 18, 2021 at 7:34 PM
    #196
    Badassmekanik
    Badassmekanik Well-Known Member
    How long does it take for the fronts to settle after installing the kit I got a little Carolina squat.
  17. Sep 18, 2021 at 8:12 PM
    #197
    shotgunbilly420
    They are a fully adjustable coil
  18. Sep 18, 2021 at 8:13 PM
    #198
    shotgunbilly420
    How big is your lift
  19. Sep 18, 2021 at 8:57 PM
    #199
    Badassmekanik
    I bought the full 3.5 kit from rough county.48D54EA8-E29B-4421-8A3D-2675A05344E5.jpg
  20. Sep 18, 2021 at 8:58 PM
    #200
    Badassmekanik
    My leaf springs are brand new as well I had the recall done maybe a month ago. If it doesn’t sag some I may have to adjust them or put a larger block in the rear.
