Rough Country Vertex coilovers???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phil4200, Oct 2, 2020.
  1. Oct 22, 2022 at 5:10 PM
    #461
    Floridarob3
    Floridarob3 Member
    Rob
    Central Florida
    2017 SR5 4x4
    Zone 6" kit, RC Vertec coilivers, 18x12 Weld's and a set of 33" Toyo RT's. More to come soon.
    Yeah, when I called them to figure out why the 6" CO's were sitting so low, they told me to crank up the preload and said they don't recommend using the spacers, but he didn't know why. I already had them, and I know it's been done before from YouTube Vids I've watched. I also didn't have the spanner wrench, and I suspect increasing the preload will stiffen the ride.
  2. Oct 22, 2022 at 5:47 PM
    #462
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have my preload little over half and ride is still nice and off-road ride quality is still good . But I do also don't like the fact yeah it sits low still in the front . My winch bumper and 12k winch is the cause .
  3. Oct 22, 2022 at 5:49 PM
    #463
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    You can rebuild to make them ride the way you want them. Rebuild and tuning is way better than off the shelf
    shotgunbilly420 and Mully like this.
  4. Oct 25, 2022 at 6:53 PM
    #464
    raginrougarou
    raginrougarou Well-Known Member
    Forrest
    2015 Gray Tacoma TRD Sport
    Been a while since I've posted here, but considering these for my 4runner. I see a few year or 2 year old posts on the thread, any updates? How are these holding up? Looking to replace my Icons that I have rebuild 3 times in 60k miles.
  5. Oct 27, 2022 at 3:54 PM
    #465
    hughesjrm
    hughesjrm Well-Known Member
    Michael
    Florida
    2003 Tacoma DC TRD
    Just Starting
    I am curious as well, to how these kits are holding up. I’ve been researching kits for months. Every kit has their pros and cons. I would love a wide stance with a 6” lift, but I’ve only gone as far as 3” on my other three Tacomas. I know how a 3” off-roads and what to expect, but how does a 6” do? Seems like I would have a lot more ground clearance. But obviously issues with CV’s and other components. I’ve been looking at rough country, pro-comp, and BDS 6” lifts, and honestly it seems like RC has the best bang for the Buck with the vertex CO. Would love to hear what other’s opinions are on the three. Regardless of the three I’m not a fan of the big blocks in the rear. Is there a way to go with a different leaf spring and smaller block? Again I just want to do this once.
  6. Oct 27, 2022 at 4:03 PM
    #466
    2Nice
    2Nice Well-Known Member
    K. King
    Boise, Idaho
    2023 TRD OR DCSB
    Ed Bassmaster just put them on his ram 1500 and loves them! Psh!
    Mully likes this.
  7. Oct 29, 2022 at 4:49 AM
    #467
    hughesjrm
    Michael
    Florida
    2003 Tacoma DC TRD
    Just Starting
    Think I’m going to pull the trigger today and get the 6” lift with vertex front and rear. RC just started a Black Friday deal. $150 off the kit plus military discount knocks about $500 off total
    shotgunbilly420 likes this.
  8. Nov 5, 2022 at 12:01 PM
    #468
    shotgunbilly420
    I've had the rc 6" lift with adjustable front coils and reservoir shocks all around . In the 1st 6 months I had a rear shock go bad due to being a dud from factory. Now I'm over a 1 1/2 years on the lift everything is good rides great . Only downfall is you don't get the full 6" lift. There is a guy on here that added a 2" spacer on his 6" lift and far as I know he hasn't had any issues . Im following him to see how everything pans out .
    raginrougarou likes this.
  9. Nov 15, 2022 at 4:19 AM
    #469
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    Anyone having a front end squeak?
    I can put my hand on the front left coil over and raise and lower the front end with a floor jack and feel vibrations as it squeaks.
  10. Nov 15, 2022 at 6:37 AM
    #470
    Sweets
    Sweets Well-Known Member
    Indiana
    2023 GMC Canyon AT4X Edition1
    Nothing here. I do have a little one in back from the leaf springs, but very minor.
  11. Nov 15, 2022 at 3:34 PM
    #471
    shotgunbilly420
    Yes after 1 year I'm not sure if it's upper and lower control arm bushings
  12. Nov 15, 2022 at 4:43 PM
    #472
    AbnMP13
    Shelby
    So you just ignoring the squeaking?
  13. Nov 15, 2022 at 4:46 PM
    #473
    Phil4200
    Phil4200 [OP] Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Try preloading the spring a little bit and/or reverse and see if it changes. What kind of upper control arms are you using?
  14. Nov 15, 2022 at 5:07 PM
    #474
    shotgunbilly420
    Pretty much on rainy days it goes away
  15. Nov 16, 2022 at 3:46 AM
    #475
    AbnMP13
    Shelby
    OEM
  16. Nov 16, 2022 at 6:25 AM
    #476
    Phil4200
    Could be your issue, not sure 3”/3.5 coil overs are supposed to be run with stock arms. In fact almost certain not
    Mully likes this.
  17. Dec 5, 2022 at 10:14 AM
    #477
    AM_Taco
    AM_Taco Well-Known Member
    2020 Tacoma TRD Off-Road
    Has anyone tried adjusting the height of these themselves. Last time I had one side raised about .25" and took it into a shop, but now Im trying to lower both sides .75"-1" and don't want to take it into a shop. Was wondering if anyone's adjusted the height successfully by jacking up the truck and cranking with the spanner wrench as opposed to removing the strut and using a spring compressor.
  18. Dec 5, 2022 at 10:30 AM
    #478
    Phil4200
    The spanner won’t fit to adjust while coil over is still on the truck. I took a 5/8” punch and inserted into top collar grooves and adjusted. They are hard as hell to adjust, the collar holes are now a bit messed up but I got the job done. I used a little cheater bar to gain leverage with punch.
  19. Dec 5, 2022 at 10:43 AM
    #479
    AM_Taco
    Good to know, thanks.
    Was there enough space to to loosen the locking nut at least? Also im assuming you have the side lifted to remove weight from the wheel? Were you increasing the height of the lift or decreasing it?
    Phil4200[QUOTED][OP] likes this.
  20. Dec 5, 2022 at 10:51 AM
    #480
    Phil4200
    6BD47372-D1AB-47BA-97AC-4BD70D2D9E20.jpg 6BD47372-D1AB-47BA-97AC-4BD70D2D9E20.jpg Yes I was able to Jack the truck up and get both tires off the ground. The wrench is double sided and it will work to loosen lock nut yes it will fit, I was increasing
    AwesomeLaw68 likes this.
