Rough County 3.5 lift (non coil overs) - anyone has it installed? stick with stock 16s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DJ KennyT, Feb 27, 2021.
  1. Feb 27, 2021 at 1:56 PM
    DJ KennyT
    DJ KennyT [OP] Member
    Kenny
    2019 Cement OR Tacoma DCLB
    In progress!
    Hello,
    Why Lift? going to be a ranch truck in a few years, taking it off road in the hill country of texas, want to give a few inches of extra space under the truck with a reasonable price. Also do like the look of a lifted truck, but nothing super crazy.
    https://www.roughcountry.com/toyota-suspension-lift-kit-742c.html?find=2019-toyota-tacoma-4wd-740124
    Thinking of putting this kit on my 2019 Offroad 4x4 taco. Will make it a 3.5 inch lift. Curious if anyone has this lift installed and how the ride quality is? Pros/Cons? General Comments?
    Install guy said adding 17 inch Toyo AT tires would be a good idea, currently running stock 16's. Anyone that has done around a 3 - 3.5 inch lift, can you keep 16's on it or does it look stupid with the amount of space in the wheel wells? Thinking about cost savings as my stock tires have a good while until I need new ones.
    In general with a 3/3.5 inch lift how much stability and performance are you going to be loosing. I assume a decrease in MPG will happen due to the extra drag added with more parts exposed to the wind and such. Also if I add bigger tires that will increase the weight.
    Lifting the truck, will that mess with the safety sensors/radar/light sensor? I know mechanically it won't just wondering if that 3 - 4 inches makes a difference in the sensor range or anything.
    Does a lift kit decrease or increase the value of your truck or is doesn't doe either? I would assume it would do neither for the resale value to a dealer, but increase to a person.
    Any comments and suggestions are welcomed, to any or all questions. Thanks guys!!
  2. Mar 17, 2021 at 11:47 AM
    Kramykram
    Kramykram Well-Known Member
    Mark
    21 Tacoma trd
    None yet
    I'd like to know the answer to this as well. A lot of hate on the rough country kits. But I've installed them on quite a few jeeps with no complaints. My truck is mostly on the road and the occasional Tline and driving over mats for work or in a substation before the rocks are put down. Bump for someone who might of installed it also.
  3. Mar 17, 2021 at 11:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    2”-2.5” is the sweet spot. IMO
    Good luck
    whatstcp and MR E30 like this.
  4. Mar 17, 2021 at 11:58 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    This, big time.
    71tattooguy[QUOTED] likes this.
  5. Mar 17, 2021 at 2:01 PM
    Kramykram
    Mark
    21 Tacoma trd
    None yet
    What do you mean by the sweet spot??
  6. Mar 17, 2021 at 2:03 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Cv angles , new upper control arms maybe needed. Then you will want 285’s and so on and so forth. Go down that worm hole if you got deep pockets. Higher is not always better :thumbsup:
    Skydvrr likes this.
  7. Mar 17, 2021 at 2:06 PM
    Kramykram
    Mark
    21 Tacoma trd
    None yet
    The OP above mentioned kit does come with arms. That's the reason I was looking at it, as well as never had problem with the jeep kits in the past. But I get what you're saying about the cv angels. Something I read about in searches but didn't know how high you would have to go before that became an issue.
  8. Mar 17, 2021 at 2:10 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    These are Tacoma’s not Jeeps so keep that in mind
  9. Mar 17, 2021 at 2:32 PM
    Kramykram
    Mark
    21 Tacoma trd
    None yet
    No doubt.
