Rough Downshift After Coming To a Stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbv808, Oct 5, 2016.
  1. Oct 5, 2016 at 3:37 PM
    jbv808
    jbv808 [OP] Well-Known Member
    Josh
    Maui, HI
    White 1995.5 Tacoma 2.7l 4x4
    -Kenwood Single Din Deck, 12" MTX Sledgehammer Sub, Orion 1500 Watt Amp -JBA Catback Exhaust w/ LCE Test Pipe and URD O2 Sensor Simulator -6 Inch Fabtech Lift (Hawaii Style!!) -Revolution Gear and Axle 4.88 Gears Front and Rear -5" Pro Comp Leaf Springs (More like 6"-7") -A340F Auto to W59 Manual Swap -2.5 Radflo Coilovers -JBA Offroad UCA's -Bilstein 5165 Rear Shocks -LC Engineering Headers -HPS Short Ram Intake -LC Engineering High Boost Supercharger w/ 5th Injector, pink top injectors, Walboro 190, Split Second Fuel/Timing Calibrator, AEM Water/Methanol Injected
    I have a 95 tacoma that seems like its downshifting hard after moving from a complete stop if that makes sense? So lets say I come to a complete stop at a red light, when the light turns green, theres a noticeable thud and a slight jerk when I let go of the brakes to start moving forward. It doesn't happen ever single time but it doesn't rarely happen either. Anyone experience this and was able to fix the issue? BTW it is automatic transmission. TIA
  2. Oct 5, 2016 at 3:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Axle wrap
  3. Oct 5, 2016 at 3:40 PM
    jbv808
    Josh
    Maui, HI
    Heard of it before but don't know much about it. Any details and how to fix it?
  4. Oct 5, 2016 at 3:43 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Greasing the u-joints on the driveshaft sometimes helps, either have the service dept do it or you can do it yourself, it's really easy. Just need a grease gun and some grease from the local auto parts store.
  5. Oct 5, 2016 at 3:48 PM
    jbv808
    Josh
    Maui, HI
    If it only "sometimes" helps is there any other solution if the issue keeps occurring or is it a permanent problem? Will definitely give greasing the u-joints a try though.
  6. Oct 5, 2016 at 3:57 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Weak leafs are causing the axle to "twist" when accelerating or braking. Suddenly releasing that tension will often cause a thud or jerk.
    At a stop the truck is already in gear and power is being transferred to the axle. That would rule out driveline slop (most of the time) because the slop has already been taken up.
  7. Nov 19, 2016 at 12:36 AM
    jbv808
    Josh
    Maui, HI
    would a better but more costly solution was replace the entire leaf spring?
  8. Nov 19, 2016 at 3:33 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
  9. Nov 19, 2016 at 4:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not at all. Vehicle is already in first gear when stopped in D. So it doesn't downshift when you start moving. It will upshift when you get to the right RPM
    I agree with others that it's likely not trans related. But regardless.............
    Is the trans properly filled? Is the fluid still a nice reddish pink, and smell like fluid from the bottle, or does it have a burnt odor? When was the last time the transmission was serviced? It's 22 years old with ???k miles. It deserves some love.
  10. Nov 19, 2016 at 5:39 PM
    Maestro
    Maestro Well-Known Member
    The Master
    Replacing the rear springs probably won't solve your problem. I recently installed a complete OME with Dakars on my 2000 pre runner and, while the ride improved, axle wrap was not significantly improved.
  11. Nov 20, 2016 at 5:56 AM
    chaosrob
    chaosrob Well-Known Member
    My 97 manual was doing this even after new leaf install until I changed the rear u joint.
  12. Nov 20, 2016 at 6:05 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Grease the slip yoke
  13. Nov 20, 2016 at 8:18 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
  14. Nov 20, 2016 at 9:19 AM
    devinzz1
    devin
    2023 aclb trd or mt
    An auto wont do that because of a u joint since theres constant force taking up any slack in that situation.
  15. Nov 20, 2016 at 12:46 PM
    chaosrob
    Maybe you're correct but I think it would depend on the amount of slop in the joint as well as the function of additional torque being supplied be pushing on the accelerator pedal. While my 5-speed technically still had resistance applied to it while driving down the highway if I let of the accelerator it would vibrate then clunk when I pushed the accelerator back down.
  16. Nov 20, 2016 at 12:58 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Yea but this is goin from a stop.
  17. Nov 20, 2016 at 1:04 PM
    chaosrob
    I understand but I am trying to understand how it is different. There is still a relaxation of torque from release of the accelerator and then there is a torque multiplier from the stop by pushing the accelerator. Perhaps I am just dense but I do not understand how it would be impossible for it to be a u joint but not the slip yoke as both would have the same constant pressure you are referring to since it is an auto, correct.? I am in no way saying this is his issue, just a suggestion.
  18. Nov 20, 2016 at 1:34 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Slip yoke thud is usually caused by it sticking not because of there being actual slop between the spines. say when braking the rear axle gets pulled back some pulling out the slip yoke. it can then get stuck in that position with force being preloaded by the leafs. when accelerating the yoke frees up and the axle jolts forward some causing a thud/clunk. this is amplified with axle wrap.
    chaosrob[QUOTED] likes this.
  19. Nov 20, 2016 at 1:35 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Sounds like axle wrap caused by weak springs. Try the u bolt mod. Even after I bought brand new General Springs I still got wrap after a few months.
    Ended up going with the u bolt mod and it's gone...
  20. Nov 20, 2016 at 1:36 PM
    chaosrob
    Got it, thank you
