Rough Engine Braking in Overdrive
Discussion in '1st Gen. Tacomas (1995-2004)' started by zwhitworth, Jan 16, 2011.
  1. Jan 16, 2011 at 6:39 PM
    zwhitworth
    zwhitworth [OP] Member
    I just bought a 2002 Tacoma V6 4wd Auto, and am new to Tacomas (had a Frontier). It has 140,000 miles and runs great other than one thing (that I didn't notice on the test drive) - when in 4th gear, the engine braking during deceleration isn't smooth. From what I've read, the Tacoma does more engine braking that the Frontier, but I'm worried there is something wrong. The engine runs fine when I'm accelerating and the transmission shifts fine too. If I turn off Overdrive, it decelerates with Engine braking more smoothly. Can someone tell me if this is normal or if this is an indication of something wrong? Any direction would be greatly appreciated.
  2. Jan 16, 2011 at 10:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    That does not sound normal. I have the same truck as you. Overdrive OFF, I definately "feel" the engine braking compared to overdrive ON. With it ON, it is very smooth and rolls a long way, very little engine braking in fact.
    What exactly are you feeling? Could it actually be driveline vibrations? Do you have a lift?
  3. Jan 17, 2011 at 5:10 AM
    zwhitworth
    No lift. It feels like vibrations toward the front of the truck. Now that you mention it, it may make sense that it is something in the driveline. While "coasting" in 4th gear, there is less "pull" or "tension" on the driveline than in 3rd. When I give it gas, the vibrations go away. I'm going to get under it and see if I can feel a loose u-joint. Any other ideas?
  4. Jan 17, 2011 at 3:41 PM
    zwhitworth
    Ok. I felt a little play in the front u-joint when moving it with my hand, but not much. I took it for a drive and put it into 4H and tried coasting down a hill and the there were no vibrations. Back to 2H and the vibrations resume. Do you think that is a valid test that points to the U-Joint(s) in the front driveline?
  5. Jan 17, 2011 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think engaging 4hi effects anything in the rear besides the t-case. It does seem indicate your vibes are in the front.
    It still could be u-joints but the likelyhood is much lower. To be certain, I would grease all 8 fittings on both drive shafts. btw: there should not be any side to side play in u-joints.
    There are a lot of threads on here about vibes happening on 2nd gens after lifting. Many times that has been an indicator of a bearing issue in the front diff. But the 1st gen front diff has proven to be more durable. Usually, vibes in the front of 1st gens are wheel balance or wheel bearing or worn cv axle joints.
    The vibe you feel is definitely on coasting right? You don't feel it on acceleration, right?
  6. Jan 18, 2011 at 5:00 AM
    zwhitworth
    Thanks for your input! I'll grease the U-Joints and see if that helps. The vibration is definitely only on coasting -- most noticeably coasting down a hill or at high speeds. Once I hit the gas, the vibrations go away.
    Originally, I thought it was only in higher gears as it is most noticeable when driving down the interstate at 60-70mph. But some test driving last night proved that the vibrations also occur when coasting down a hill even at 20-40mph.
    The small amount of movement when I try to move the front u-joint is not even 1/4 inch of movement, but i wonder if that becomes worse at higher revolutions.
    If it were the CV Joints or wheel bearings, would I feel the vibrations during acceleration as well?
  7. Jan 18, 2011 at 9:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I think you would as long as 4hi wasn't engaged.
  8. Jan 22, 2011 at 6:25 PM
    zwhitworth
    After greasing all the u-joints in the driveline, both front and rear, the vibration still exists. Some additional findings (along with the original):
    1. Vibration only occurs when decelerating and not when decelerating uphill.
    2. Vibration only occurs in 2wd.
    3. Vibration only occurs in drive, stops in neutral.
    4. On deceleration, Vibration begins around 1500 rpm (continues as rpms decrease) and accompanies a slight wiggle in the RPM gauge needle.
    5. Vibration doesn't happen every time even when other factors are at play (about 75% of the time).
    Does this add up to something? I'm going to check the front and rear diff fluids tomorrow.
  9. Nov 8, 2011 at 12:00 AM
    mbtaco
    mbtaco New Member
    Santa Fe, NM
    '02 3.4L $WD SR5
    KNN, fabtech front lift
    I had a similar vibration behavior. It turned out to be the driveline support bearing. Your vibe seems to be noticeably upfront. the support is aft, so perhaps a non starter.
