Rough engine sounds and vibration since skid plate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wic07001, Nov 23, 2016.
  1. Nov 23, 2016 at 1:31 PM
    Wic07001
    Wic07001 [OP] Well-Known Member
    Matthew
    Idaho
    2014 White TRD Sport
    5100's front, Icon 2.0RR rear, Icon AAL, OME 885, Camburg UCA, retrofit headlights,
    so since I installed my set of skid plates on my Tacoma I've had a weird engine vibration on start up and idling. I don't know what the cause is and I'm wondering if anyone else has experienced this with theirs. Full set of RCI skids.
  2. Nov 23, 2016 at 1:48 PM
    eon_blue
    Azusa, CA
    If it happened after you installed the skids then it's probably a loose bolt on the skids somewhere. Have you gone over everything to make sure it's tight?
  3. Nov 23, 2016 at 1:51 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Probably rattling against the exhaust
    12TRDTacoma likes this.
  4. Nov 23, 2016 at 1:53 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Front diff could be contacting ifs skid
  5. Nov 23, 2016 at 2:00 PM
    Pigpen
    Dan
    Northwest Montana
    If it's a full skis set with the stock exhaust routing, then I'd guess it's hitting the low spot on the exhaust. Otherwise, I'd guess you have a loose bolt. I needed to put a washer on one of the small bolts on my IFS due to stripped threads. I'll tap them some day. Maybe.
  6. Nov 23, 2016 at 2:07 PM
    Wic07001
    Matthew
    Idaho
    What torque did you guys torque everything to?
  7. Nov 23, 2016 at 2:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's the exhaust. Worm drive band clamps on the exhaust hangers right by the T case skid will remedy your issue. I had to do it to mine for my T case skid.
  8. Nov 23, 2016 at 2:10 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I'm having this rattle, but it was because something happened to the heat shielding when I did an exhaust reroute. Do you think you may have knocked it when you did your install?
    After you check for loose bolts, check the shielding.
  9. Nov 23, 2016 at 8:13 PM
    Wic07001
    Matthew
    Idaho
    What do those look like and do you have a pic showing me how yours looks?
  10. Nov 23, 2016 at 8:16 PM
    Wic07001
    Matthew
    Idaho
    My little guy might have knocked it so ill check that as well. Didn't think of that. Love this site. You guys are way more insightful than the Toyota dealer. Thanks for everyone's speedy replies.
  11. Nov 23, 2016 at 8:36 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Skids also seem to amplify sound in my experience, "trapping" it between the body and the plate. I've taken to spraying rubberized undercoating on the truck side of skids so long as it's not exposed to high heat like the exhaust. They'll hold a little more dirt and mud so you have to rinse periodically but I do that anyways.
  12. Nov 24, 2016 at 12:31 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can take them. All they do is move up the exhaust and not allow them to rest on the hangers as much. Less sag.
