Rough/Grid feeling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jacobsn4339, Nov 6, 2022.
  1. Nov 6, 2022 at 4:17 PM
    jacobsn4339
    jacobsn4339 [OP] New Member
    NJ
    2013 White Tacoma SR5 double cab
    Went to pull my truck out of my garage after not driving a few days. Truck was very rough almost felt like driving over paver stones, heavy vibration in cabin of truck. Even had the same problem in reverse. After about 10 minutes looking at the issue, couldn’t find anything. Then the problem self corrected itself and the vibration/grinding went away. It was definitely coming from the rear passenger wheel. Trying to figure if it’s a brake issue or wheel bearing problem? No lights on dash, brake fluid was full also. Any ideas?
  2. Nov 6, 2022 at 4:19 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Drum brake sticking
    Geeves77 likes this.
  3. Nov 7, 2022 at 5:33 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Could also be flat spots on the tires? I've experienced that on underinflated tires, but with modern radials it usually goes away after like 1/4-1/2 mile
  4. Nov 7, 2022 at 5:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe some water got in the drum and rusted? It can scrape a little until the surface rust gets rubbed off
  5. Nov 7, 2022 at 7:59 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    yeah, I would guess drum issue also..
