Rough handling and shimmy over bumps and potholes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cole1999yota, Oct 7, 2021.
  1. Oct 7, 2021 at 2:44 PM
    Cole1999yota
    Cole1999yota [OP] Member
    1999 Toyota Tacoma prerunner
    Just got a suspension inspection and was told everything was tight and in good shape. But every time I hit a large bump or go over rough roads I lose control and it feels like my front end lifts off the ground at higher speeds. I have a 99 prerunner with 212k miles and everything is up to date. Any advice would be great, thanks
  2. Oct 7, 2021 at 2:47 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just how fast are you going?
    If the roads are that bad slow down or avoid them.
    JudoJohn likes this.
  3. Oct 7, 2021 at 2:59 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    In my experience, some techs just cant be bothered, or dont know what to look for. Additionally, they’re usually really only looking for obviously broken stuff, not stuff that can wear out and make a difference. For example I took my truck to two mechanics a total of 4 or so times with wild wandering issues and specifically asked them to check suspension. nobody noticed the crumbling sway bar bushings or that my rack and pinion was moving around like crazy due to loose bolts. I had to do it myself. Unfortunately you just cant pay someone else to give a shit, it seems. Also, they don’t drive your truck normally so they don’t know what it feels like.
    in my experience the sway bar bushings and rack and pinion bushings made a bigg difference. The rear leafs are weak now and causing a little wiggle, so i have an add a leaf on the way.
    JudoJohn, skeezix and aroma like this.
  4. Oct 7, 2021 at 3:30 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Agreed Rastopher.
    Check tire pressures as well. I had gross over inflation of my tires after a balance and rotate that it made my truck scary as shit to drive. It floated all over and was super sketchy.
    You know how old your shocks are, so check for fluid. Bushings, are big. Alignments are big. Inner and outer tie rods are big. Again, you know your ball joint situation so check and replace those too....
    JudoJohn and Rastopher like this.
  5. Oct 7, 2021 at 3:31 PM
    eon_blue
    Azusa, CA
    A lot of shops over-inflate tires, it really is kind of worrisome. I swear they see the "MAX PSI" rating on the sidewall and figure it's the PSI they should be set at. I had a tire shop put mine to 50+ psi once. Felt like the back end was going to swing out on me on the highway
  6. Oct 7, 2021 at 3:53 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    When were the shocks last changed out or rebuilt?
  7. Oct 7, 2021 at 7:29 PM
    Glamisman
    Glamisman Well-Known Member
    if the front struts are original they are way past their prime.
  8. Oct 7, 2021 at 10:37 PM
    Rastopher
    Ras
    Sacramento, Ca
    Same with coils and leafs
  9. Oct 7, 2021 at 10:51 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    My new tires were over inflated when I got them, had to take 10 psi out of them and they feel pretty good now.
