rough iddle at start, throws codes
Discussion in 'General Tacoma Talk' started by kingbelga, Apr 23, 2025.
  1. Apr 23, 2025 at 7:11 PM
    kingbelga
    kingbelga [OP] New Member
    I have a 2004 2.7l manual trans 4wd Taco.
    it has a rough idle in the morning and will throw codes and an engine light. (300,302,303)
    If i throttle up for a bit it will go away and evades the codes most of the time ( after reseting them of course)
    it runs fine all day after no probs, same thing day after day.
    anywho, its not MAF, top sensor, coils or plugs.
    and now it will ping a bit after i get it to idle proper as throttle unless i wait a bit first as to warm up or something, lol.
    my thoughts are its my EGR valve stuck, clogged or broke.
    im going to remove it and clean it or replace it and the egr modulator as well.
    any thoughts?
    KeaganKing likes this.
  2. Apr 23, 2025 at 7:40 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2012 SR5 4x4 ACab with Old Man Package, MT, 2.7L, Spruce Mica
    Camper Shell w/roof rack, Bed stiffeners, Step Bars
    I'm having a similar issue, but mine's a 2012 2.7L. I don't get codes though. yet
    Hoping someone will chime in with suggestions.
    By the way, welcome to Tacoma World. Lots of good people here.
  3. Apr 24, 2025 at 8:22 AM
    KeaganKing
    KeaganKing kingkeagan07
    Keagan
    Boise, Idaho
    95 3.4 5 SPD 4x4 xcab
    check this thread out. Been having similar issues with my truck. different motor, but maybe mention your truck/s and get some insight.
    https://www.tacomaworld.com/threads/valve-adjustments-on-5vz.857296/#post-30583253
    po35042 likes this.
  4. Apr 25, 2025 at 9:02 AM
    kingbelga
    yeah it aint no head gasket or it wouldnt go away. no broken fan blade hence it wouldnt go away either. and if it was valves then it in theory shouldnt go away. low flow fuel filter shouldnt go away either. feels more EGR related as it casues the effects of stuck closed and open. hence casueing misfire code and vibration until or unless throttled. ughh, maybe ill just buck up get the system cleaned checked, tune up etc, then see if it persists, then change egr, lol
    its so maddening because its only at start in beginning of day never after till next day without fail, clockwork . heck, rest of day after first start, perfect.
