rough idle 4 cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Feb 2, 2011.
  1. Feb 2, 2011 at 11:32 PM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    well my 2.7L four banger idles real rough some times. it mainly when i come to red lights and am sitting. if i leave the truck in drive the thing turn into a giant vibrator. when i pop it in neutral i notice that it only vibrates when it idles below 800rpm. is there any way to turn up the idle slightly or fix this problem?
  2. Feb 3, 2011 at 9:20 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I've had the same problem since day 1. It's normal. The engine puts stress on the drivetrain trying to turn the ds and rear end... causing vibrations. Of course when it's in nuetral there is no stress... Kinda make sense now that it's explained?
  3. Feb 3, 2011 at 9:26 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    put it in nuetral at lights i do that in my other car since my truck in mt
  4. Feb 3, 2011 at 9:30 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    i already do that but i shouldnt vibrate so bad i feel like the truck is gonna fall apart. if the O2 sensor was causing the problem wouldn't it have throw a check engine light?
  5. Feb 9, 2011 at 7:13 AM
    1flossedTRD
    1flossedTRD Member
    NY
    02 SR5 4X4
    SAME thing happens to my 02 4 cylinder. Not sure what the issue is.. Does NOT happen in park, only drive at a stop light.
  6. Feb 9, 2011 at 10:55 AM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    my 01 4 banger has been doing this for about the last 4 years (i cant remember if it did that before then but if it did im sure i would have noticed it) and i am out of options on how to fix it. ive learned to live with it even though it is still annoying as hell, not sure if mine does it in park but it does it in D and N when the rpms are settled at about 700, if something like the compressor kicks on and raises the rpms then it will stop until it settles back down. i have tried everything! maybe its either a worm motor mount or small vacuum/exhaust leak that i cant find
    *i had the o2 sensors replaced a year ago and it hasnt changed anything
  7. Feb 9, 2011 at 10:57 AM
    1flossedTRD
    1flossedTRD Member
    NY
    02 SR5 4X4
