Rough idle and missing
Discussion in '1st Gen. Tacomas (1995-2004)' started by shark19, Jul 2, 2009.
  1. Jul 8, 2009 at 8:36 PM
    #41
    shark19
    shark19 [OP] Member
    Port Orange, FL
    02 PreRunner V6 TRD QuadCab
    K&N
    mass air sensor cleaned but truck ran the same.
  2. Jul 8, 2009 at 8:44 PM
    #42
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    I'm out of ideas, and with out the truck in front of me, there's not much else I can do. I hope you get it figured out, and it's something cheap/easy to fix.
  3. Jul 19, 2009 at 6:24 AM
    #43
    shark19
    shark19 [OP] Member
    Port Orange, FL
    K&N
    Here is the result $882.00 later. The water pump seized and spilled some antifreeze into the timing chain area. The idler came apart and caused the timing chain to jump a tooth. Took the Toyota dealership a day to figure it out after they called me a few times and asked about all the stuff you guys had me try. This was a funky one, I have heard of timing chains breaking but not jumping a tooth like that. I never saw a leak on the truck and never overheated so did not even think about the water pump.
    Thanks for all the help.
  4. Jul 19, 2009 at 6:26 AM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WOW! I never would have guessed the water pump.....
  5. Jul 19, 2009 at 6:29 AM
    #45
    kevhogaz
    SR5 PreRunner
    Your truck has a timing belt, not a chain, and they do jump teeth on occasion. This right here is why I said I hate to diagnose over the internet. If I could have heard it, and seen it, it would have been a lot easier to fix.
    I'm glad you got it squared away, but sorry you had to spend all that money.
