Rough idle cuts out when throttle applied
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blevs89, Jan 14, 2020.
  1. Jan 14, 2020 at 2:53 PM
    Blevs89
    Blevs89 [OP] New Member
    Damien
    2000 Tacoma 2.7 4x4
    3" on 33s
    2000 Tacoma 2.7
    Head redone new plugs water pump thermostat radiator tps idle control engine coolant sensor air filter fuel regulator fuel filter and all the gaskets egr delete
    Rough idle barley takes off without feathering the throttle runs decent after you are in third gear at 3grand go to shift to fourth falls on its face cracks and pops cuts out let off throttle and almost wants to die
  2. Jan 14, 2020 at 3:10 PM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    How’s the timing? Maybe a vacuum leak.
  3. Jan 14, 2020 at 10:54 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Sounds like the crank angle sensor is on its way out. Are you getting any codes?
  4. Jan 15, 2020 at 5:56 AM
    Blevs89
    Damien
    2000 Tacoma 2.7 4x4
    3" on 33s
    All vacuum is good no leaks. I set the timing and hope I got it right I checked it twice but would being off one tooth one way or the other would it still run it seemed black and white but timing has crossed my mind to check it again... I have no codes since I bought it, has a light come on the cat was already took out assuming the o2 sensors were deleted or they just took the lights out of the dash...they sent 2 resistors with the egr delete kit I put one on the egr temp connector where would the other one go? I haven't checked the crank angle sensor...
