Rough idle issue!!!
Discussion in 'Performance and Tuning' started by ETaco23, Mar 5, 2009.
  1. Mar 5, 2009 at 12:26 AM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I've been having a rough idle issue for quite a while now! Ive done quite a bit to try to get rid of it, like Seafoaming, cleaning AMF, TB. But it hasn't really helped!
    Tomarrow I plan on checking my plugs and wires. and changing my Fuel filter. Hope that helps! But was wondering if you guys have anything else I should check or do?
  2. Mar 5, 2009 at 5:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When you change your plugs, use the twin ground Denso's. Gap them to .040 both sides.
  3. Mar 5, 2009 at 6:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Define rough idle.
    Fluctuation in RPM's during idle?
    or
    Feels like a miss?
    Only happens during idle?
    Any CEL?
    and check the butterfly plate to see if it returns all the way or may be stuck.
  4. Mar 5, 2009 at 11:19 AM
    ETaco23
    Evan
    PNW
    thanks guys! Well my rpm's fluctuate and is rough only at stop light and such. The truck actually vibrates a little. it wasn't like this when I first bought the truck, it ran smooth. I can def. tell its not right.
  5. Mar 5, 2009 at 11:21 AM
    ETaco23
    Evan
    PNW
    Ive never gapped plugs before, how would I go about doing so? Dont those plugs come gaped like at .044?
  6. Mar 5, 2009 at 11:39 AM
    ETaco23
    Evan
    PNW
    Never mind chris! I looked it up!:)
  7. Mar 5, 2009 at 11:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok, Cool. No plugs come "Pre Gapped". I dont care what anyone says.
  8. Mar 5, 2009 at 11:49 AM
    ETaco23
    Evan
    PNW
    Alright! cool:D well wish me luck on my problem!
  9. Mar 5, 2009 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    x 2
    Even if they did I would still check them.
    Sounds like you have a bad wire. You can check this by idling the truck at night with the hood propped open. Watch your wires, in the dark, and see if there is an arc jump. You may have to wiggle the wires around but just be aware of the moving components.
  10. Mar 5, 2009 at 1:43 PM
    ETaco23
    Evan
    PNW
    I'll check it out! But I think Im just ganna get a new set of wires, since mine are still factory. But first im ganna change plugs and fuel filter and see how that does. If still rough ill go ahead and get new wires. I hope this gets rid of it though!
  11. Mar 5, 2009 at 1:45 PM
    98tacoma27
    Ben
    Not Beech Creek
    I am just surprised there is no CEL. Keep us informed and happy fixing!!
  12. Mar 5, 2009 at 1:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey man....did you by chance clean the iac valve yet? you may need to take it off the throttle body to get it good and clean.
  13. Mar 5, 2009 at 3:15 PM
    ETaco23
    Evan
    PNW
    No I havent checked it yet. That would be the last thing I check!:)
    I know it could verry well be my IACV, but I would like to get the other things done first and then see what happens, before I go and pull the TB off and get into all that. ya know!
  14. Mar 5, 2009 at 3:16 PM
    ETaco23
    Evan
    PNW
    wheres a good place I can get new Plugs? will my local NAPA have the ones I need? I just picked up my fuel filter from them.:)
  15. Mar 5, 2009 at 3:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check and see.....they may carry ngk and denso......and i'd go with the denso's. or, you can get them at the dealership.....real cheap too for the normal plugs....bout $3 a piece.
  16. Mar 5, 2009 at 3:46 PM
    ETaco23
    Evan
    PNW
    K, ill check!
    Oh! and by the way guys, the economy has come to get me. Boss has told me that we dont have anymore jobs lined up after the 2 were about to finish, So im currently out of work for the moment and am filing for unemployment until we get a new job. :(
    This F**kin sucks!!!!
  17. Mar 5, 2009 at 3:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sorry to hear man. Good luck with everything!
  18. Mar 5, 2009 at 3:52 PM
    ETaco23
    Evan
    PNW
    Thanks! Im ganna need it!
  19. Mar 5, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sorry to hear about the job, Buddy. I have been out of work since before Christmas myself.
  20. Mar 5, 2009 at 4:39 PM
    ETaco23
    Evan
    PNW
    wow! I really hope we get a job soon. He's planning on setting up at a Home and Garden show soon, to try and get a bite.
    Crossing my fingers!!!
